KLX needs more power!!!
Old Feb 19, 2012 | 07:28 PM
On the big bore issue, I think something isn't optimum with the 250 displacement on this engine. Yes, I know it started life as a 250 before a 300, but the engine just seems ill suited to good power output at 250. Even when you inspect the 250 piston, you see the valve reliefs are way down the sides of the piston toward the top ring. I don't think this is optimum for good intake flow or flame front for combustion. Just going to the 300 jug, which is really 292cc, it seems to wake this engine up way more than the percentage increase of 43cc. When you do any displacement increase from the 300 jug on up, this engine just comes to life. Don't get me wrong, however, when it comes to adding a pipe, opening the intake, and proper jetting. The stock 250 engine definitely picks up more mid-range and top end with those mods. I think the engine is absolutely horrible in stock trim.
Old Feb 19, 2012 | 10:31 PM
stro's Avatar
second that, stock its more like a 125cc bike. I would get the big bore even before the muffler (just drill out the stock one) for the cost diff ,jet it and snorkle and you will have some torque to play with even in this form.
Old Feb 20, 2012 | 03:16 AM
james951753's Avatar
Does anybody have Bill Blue contact information?
Old Feb 20, 2012 | 06:15 AM
2007 Green Machine's Avatar
Wow, first post after being a member for 5 months.
bandbcyclerestoration.com
Old Feb 20, 2012 | 12:02 PM
linkin5's Avatar
Pipes, filters and jet kets would still add to the thrust of a bigbore kit so which ever way you go your not throwing money away.
Old Feb 20, 2012 | 06:02 PM
Careful with the drill out on stock. It was very popular early on, but others have confirmed there is little if any benefit, and it ruins the spark arrester, which you probably need for riding on any public off road trails.
Old Feb 20, 2012 | 06:13 PM
wildcard's Avatar
THIS ^^^
Don't bother drilling out the stocker, it does nothing. If you want more flow out of the stock exhaust you need to cut out the crappy "straw" of an exhaust outlet and put an end-cap with a larger opening on there.
Old Feb 20, 2012 | 09:53 PM
KLXHunter's Avatar
Theres NO replacement for displacement. I was extremely let down once I got my 2010. I dumped a few more hundred in it... and Im still not impressed. The carb on that bike sucks too.
This fall... carb & big bore... with all the listed mods.. then she will kick *** for woods bike. I bought mine for the woods because I need it to be registered and street legal! Great size for the price....
Old Feb 20, 2012 | 11:56 PM
Originally Posted by wildcard
THIS ^^^
Wildcard,
What happens to the spark arrester? Is it damaged in the process?
Old Feb 21, 2012 | 12:53 AM
wildcard's Avatar
Wildcard,
If i hadn't already drilled the pipe my mods would have kept the spark arrester intact. Its actually pretty far down in there behind 2 baffles that the "straw" exhaust outlet is attached to. If you simply cut out the straw and not go anyfurther down into the pipe the spark arrester remains untouched.
KMK
Nov 18, 2011 10:27 PM
CousinLarry
Jan 6, 2010 07:03 PM
Frontier
Nov 17, 2009 04:46 PM
KDXmike
Mar 19, 2009 05:46 PM
Finger Mullet
Apr 25, 2008 07:32 AM
