KLX modifications
Old Apr 11, 2007 | 11:31 PM
flotownJ's Avatar
Default RE: KLX modifications
what exactly do i need to do to the airbox lid?
what kind/brand of jets did you use and what size?
Old Apr 11, 2007 | 11:52 PM
ORIGINAL: flotownJ
i am looking to order a full muzzy system shortly. do i order the one for the klx 300?
also does that go the same for jet kits?
Yea its the 300, mine even has "KLX 300" stamped on it.
Old Apr 11, 2007 | 11:53 PM
Whoops wrong thread...
Old Apr 11, 2007 | 11:58 PM
dmar's Avatar
You will have to let more air into the airbox, the stock snorkel under the seat is way to small, alot of people intall a high flow snorkel or just remove the snorkel. A few don't run a airbox lid at all. Before my 300 upgrade I used the stock 35 pilot jet and a 124 main jet, also took the air screw out 2 turns. With the 300 in I still used the stock 35 pilot, a 132 main, These jets are from a dynojet kit for a klx300. Also a high flow air filter like uni or k and n is good. Also the same as the klx300. These jets I used was with a full muzzy system. I installed a high flow snorkel and cut a hole in the lid on mine, I didn't like removing the lid completely. Your altitude will also play a factor in your jetting. If you have the funds you can have a shop rejet it for you and have them put it on their co2 machine for correct jetting with whatever mods you will be doing.
Old Apr 12, 2007 | 12:06 AM
JB1's Avatar
JB1
Heres what I used, I run a two brothers exhaust
16009-1912--------Needle-Jet,N1TC
92143-1667--------Needle Collar (required for N1TC needle)
92037-1401--------Clamp, Needle Jet (Clip, required for N1TC needle)
92063-1074--------#128 Main Jet
92064-1108--------#40 Pilot Jet
KFS-3--------------Koubalink adjustable air/fuel t-handle screw
14073-1577--------Duct, Inlet (KDX200 Snorkel)
NU-2364ST--------UNI air filter
https://www.kawasakiforums.com/m_67995/tm.htm
https://www.kawasakiforums.com/m_100000/tm.htm
anciano
Mar 27, 2015 09:48 PM
mcbain
Mar 27, 2010 05:03 AM
RandyZZR
ZZR 600
May 6, 2007 04:11 AM
trickstyle25
Sep 22, 2006 12:05 PM
Jayson
May 31, 2006 11:11 PM
