KLX Chains, Sprockets & Gear Ratios.
Old May 4, 2008 | 09:29 PM
  #41
SavageKen's Avatar
Default RE: KLX Chains, Sprockets & Gear Ratios.
I was looking for sprockets on the net and i found this link:
http://www.sprocketcenter.com/c/16585/1/kawasaki.html
They sell KLX300 Sprocket and chain sets ( Sidewinder- Front Rear and chain) These should fit our 250's since I read back a few posts that the 300 sprockets are the same as ours.
Ken
Old May 4, 2008 | 09:55 PM
  #42
djmerullo's Avatar
Hey west, I forgot to tell u that I run a 47 tooth rear and it seems to be fine. I went with a 110 chain and I cut it to my exact length that i wanted. It worked out great. If Its to long u can always grind or use a chain press. but U cant really make a chain longer tho.
Old May 4, 2008 | 10:19 PM
  #43
Davebert's Avatar
Maybe this will help...I have been working on it in my spare time and will finish it one day.
db
Old May 4, 2008 | 10:48 PM
  #44
djmerullo's Avatar
where did u get that info bro?
Old May 5, 2008 | 01:27 AM
  #45
Davebert's Avatar
ORIGINAL: djmerullo
Its an application I have been working on. Its accurate with a gps but indicated readings vary as the speedos are off by up to about 10% average. Tire sizes also contribute to the inaccuracy so I wrote this to allow user inputs to tweak as necessary for most accurate results. Its not ready yet as I want to add a lot more different bikes to the choices but thought I would throw out a shot to see what people think.
db
Old May 5, 2008 | 02:11 AM
  #46
WestOzKLX's Avatar
Thanks for that Dave. That's what I was looking for.
I want to cruise at about 70 at 8000 RPM in top.
Old May 5, 2008 | 04:29 AM
  #47
djmerullo's Avatar
btw people a 16 tooth from bikebandit.com will not fit the 06 250. And btw here is a cheap rear sprocket. http://www.bikebandit.com/product/A5849106
Old May 5, 2008 | 04:31 AM
  #48
djmerullo's Avatar
http://www.bikebandit.com/product/A5842859this one doesnt fit. (the 16)
Old May 5, 2008 | 10:06 AM
  #49
MaverickAus's Avatar
ORIGINAL: 09KLXowner
I went with 13/45 and it was great down low but would still cruise at 60mph w/out too much rpm increase. I think several have this combo and it's been said that it is the most versatile for the bike's abilities both on/off-road.
I have this combo for off road its awesome, but far too many revs onroad unless you never go over 50mph
Old May 5, 2008 | 09:25 PM
  #50
Davebert's Avatar
ORIGINAL: WestOzKLX
No problem. Thats a 14-49 in the pic and at 8000 rpm its about 66 mph.
db
