KLX 351 Kit Install
Old Dec 2, 2017 | 12:43 AM
snappster's Avatar
I installed Barnett springs with the original clutch. It slips a little but only at WOT which I don't do much of. I might look into shimming the springs to increase the clamping force a little. Interesting that at 800' you were so rich. I run a DJ140 main jet with 2n needle position and get 65mpg all the time. Could be a little lean or rich but I can live with the mpg and it runs good.
Old Dec 2, 2017 | 01:35 AM
GBAUTO's Avatar
I use an EBC DRC212 with Barnett spring 501-25-06043. I run Rotella 15-40 dino and it does a good job. I also remember that the 351 seemed to have a stronger vacuum signal to the carb so it did run a bit rich on jetting for the 250.
Old Dec 2, 2017 | 02:22 AM
SuperMo's Avatar
Talking
Yea I'll have to wait until it's broken in to see how it's reacting in the higher rpm range jetting wise, but for now I seem to be close.
I may change the oil again too ... I was running Kawi M4 mineral oil and then the last oil change I used Motul 7100 100% synthetic (before I ordered the 351 kit). I talked to Bill and he suggested non-synthetic so I picked up some Castrol GTX for the time being. I changed it twice to get the Motul out but it's still slipping pretty bad. Anyways, I ordered the 501-25-06043 springs this evening, I'll see how they work with the stock clutch. I don't mind getting a new clutch, it's all part of the fun!
Re: Stronger vacuum with the 351, I was thinking the same thing. The bike was drowning in fuel with the only changes being a single washer under the e-clip and one main jet larger, crazy.
It's going to be a balmy 7 degrees C tomorrow, I should be able to put 50-100km on it before I freeze
Old Dec 2, 2017 | 02:53 AM
RaceGass's Avatar
Iirc on another site planet klx a recommendation on using kx125 plates (not sure what yr) helps. I'm running that ebc clutch kit w Barnett springs and still have slippage in 4,5,6 if on the street/wfo. I was going to try to use washers to preload the springs but haven't seen anyone do that yet so I'm hesitant. But I will try the kx plates next.
Wonder if there are any compatable springs besides the Barnett replacement springs. I remember using cr500 clutch springs in a 250 (3 cr500, 3 stock oem) and that helped but lever pull was affected as well.
Old Dec 2, 2017 | 12:11 PM
SuperMo's Avatar
I was doing a bit more reading and found that you can use three of the springs built for our bike (# 501-25-06043 ) and three heavier #501-40-06017 springs. Supposedly the latter are 38 pound springs. Does anyone know where to find a list of Barnett's spring specs?
Old Dec 2, 2017 | 01:04 PM
durielk's Avatar
I would replace the clutch plates, IMO they retain oil and you will never get it out no matter how many times you change the oil. I would not recommend using other than standard oil, it just works, what else do you need. Going to syn oil has no advantages on the mileage/time for a dirt bike.
Old Dec 2, 2017 | 10:03 PM
SuperMo's Avatar
I ended up breaking one of the bolts holding the springs in today so I'm definitely ordering new clutch plates. I was pulling away from a stop sign and it went, I immediately shut it off. I got the bolt out and put three stock and three heavier springs from a YZ 2 stroke I had lying around until I get the Barnett springs and new clutch plates. I have ~130km on the BB kit now.
Old Dec 2, 2017 | 10:12 PM
Tacoma660's Avatar
Any issues other than the clutch springs? I had the shop put heavier springs in when they replaced my clutch pack in preparation for the 351
Old Dec 2, 2017 | 11:12 PM
SuperMo's Avatar
No issues with the piston/cylinder at all. I did have the slide stick open in the carb today after I pinned it a bit in second. The diaphragm has expanded so I'm guessing I didn't get it perfectly back in the groove, I think it's good now.
Old Dec 2, 2017 | 11:27 PM
SuperMo's Avatar
Edit: Did some reading, looks like the EBC DRC works for other members here, I have ordered it.
