KLX 331 EFI need help!
Old 08-17-2015, 07:30 PM
Thornton27's Avatar
Default KLX 331 EFI need help!
Hello!
I dont get my KLX 331 EFI 2010 to go above 130 km/h
Things ive done.
Bill Blue 331 kit
Leovince silencer
KDX 200 Snorkel
12oclock speedometer
EJK Controller kit "Big Bore"
o2 sensor removal
backfire screen removed
Twin air filter
Clutch switch restriction
14/39 sprockets also tried 14/42
and ive done this:
1. Disconnect ECU from the rubber base (A)
2. Locate the light green wire (:doh:
3. Cut the light green wire close to ECU
4. Add a piece of wire to the light green wire (that you just have cut) to the side that comes out of the ECU (E) long enough to reach (F)
5. Disconnect (F)
6. Connect the wire you added, in parallel to the black/red wire (G)
7. Connect again (F)
8. Isolate the light green wire that was coming to ECU (D)
With the 14/39 sprockets i get the bike to 125-135 km/h no power wheelies.
and with 14/42 sprockets i get the bike to 115-122 km/h and can power wheelie at 1st gear..
Please help me this is getting pretty annoying
Sorry for bad english!
EDIT : Forgot to mension ive got supermotard wheels.
Old 08-18-2015, 04:16 AM
JoelThailand's Avatar
Originally Posted by Thornton27
and ive done this:
5. Disconnect (F)
All the wire cutting was totally unnecessary as the "clutch bypass" takes the restriction away in 4,5,6th gear. 1st & 2nd gear is unrestricted by the ecu so power wheelies should be no problem for a 331 bike!
I have no idea what problems or issues that could arise from all the cutting & slicing wires could cause. Maybe the clutch bypass is conflicting with the all the ecu wire cutting?!?
Old 08-21-2015, 07:20 PM
Thornton27's Avatar
Thanks for your answer! I have read alot of your comments before i orderd the 331 kit! Hmm maybe i shall try to return the ecu to stock worth a try! Are you able to power wheelie your 331 in 1,2,3? And does the web cams have any effect on the torque or is it just more rpm?
Old 08-22-2015, 11:06 AM
Yes worth taking ecu back to stock.
Only power wheelies in 1st on stock gearing 14/39 but will come up easy in 2nd with a blip of the throttle or a bit of clutch. 13/39 gearing is when wheeliegedon starts happening!!
Webcams improve the low & mid torque a touch but really they help keep the power curve strong to the redline instead of starting to drop off over 8500rpm. I had access to an old set of stock cams which made it much cheaper not to pay a core charge btw....if i didn't have them to hand i may not have bothered but the extra power is nice.
Tezh58
07-15-2019 10:14 AM
kwakajack04
12-25-2015 02:28 PM
Dive2you
08-01-2010 08:42 PM
cpr1
02-09-2009 03:28 AM
Team FTB
04-23-2008 01:29 AM
Quick Reply: KLX 331 EFI need help!
