KLX-300 front wheel?
Old May 26, 2009 | 07:00 PM
Sid Post's Avatar
Default KLX-300 front wheel?
Will a KLX-300 front wheel fit our KLX-250S's?
I would like to mount a true offroad front tire on a wheel and keep a street tire on the other. I think this would be ~$250 cheaper then getting an Excel front wheel.
If I go with an Excel, what sort of total cost am I looking at? Can I get a complete front hub and add a disc brake and have someone lace up the Excel rim?
Thanks!
Old May 26, 2009 | 08:52 PM
GreenMonsta's Avatar
What year? Might not have the speedo drive but "should" fit. Cross refrence part# on Bikebandit etc. My front wheel is off a 98 KDX200 with speedo drive for an 06
Old May 26, 2009 | 09:33 PM
je2000's Avatar
For reference, you can take off a grease seal ring from the 250 speedo and it still works. It may not fit on the wheel without removing it. I do this on my 09 250s when the SM wheels are mounted.
The hubs were from a KLX650 I believe so it's highly possible you will run into the same issue, with an easy fix.
Old May 26, 2009 | 10:47 PM
Sid Post's Avatar
I believe it is from a 2007 KLX-300. It looks near brand new. The tire on it is barely worn and stock. I'm guessing the previous owner put SuperMoto wheels on and this one has just been sitting around.
Old May 27, 2009 | 04:55 PM
lcpl0331's Avatar
it'll fit
Pepe72
Apr 4, 2014 03:02 PM
maineack bob
Mar 11, 2009 11:05 PM
Sid Post
Jan 27, 2009 01:46 PM
Sid Post
Apr 22, 2008 04:26 PM
tennisman
Jan 29, 2007 12:20 AM
