KLX 250S FI lamp idle 3k problem
Old Mar 4, 2016 | 07:06 PM
jdmpower's Avatar
Unhappy KLX 250S FI lamp idle 3k problem
Hi Forum,
My first post this forum , i have a problem my bike
2011 KLX 250S EFI , @11K
problem starting after month,
some time first start , some times after 2-3minutes
fi lamp on & idle speed fixing 3k rpm.
i did'nt find this issue many forum.
br
Old Mar 7, 2016 | 02:17 PM
JoelThailand's Avatar
Welcome to the forum & just so you know 95% of the bikes on here are US carb model not FI.
Could be a pressure or vacuum lock in the fuel tank causing FI light.
Next time it doesn't start, open & close the fuel cap then try & start her again.
Old May 15, 2017 | 11:23 PM
jdmpower's Avatar
Cool
i selled my bike friend,i bougth new versys 2016 650 abs
After 1 year solved solution,KLX ECU connector location 2 cables peeled sometimes short circuit chase
Before every sensor check long time searching!..
Services says tps,alternator,crankshaft sensor, Idle talks!..
preload
May 24, 2021 02:58 AM
gthomas17
Sep 30, 2015 06:53 AM
Gone Green
Aug 29, 2012 01:17 AM
WHIP-N-DIP
Jun 8, 2012 01:31 AM
Knivez
Nov 18, 2006 01:19 PM
