klx 250 engine wiring help please
Old Jun 20, 2014 | 04:04 AM
2veedubs's Avatar
Swap the parts from the 09 to the 07 motor. Make it work with the 09 wiring. You have all the parts from the 09... Make it happen.
Old Jun 22, 2014 | 05:25 PM
dziuggy's Avatar
Originally Posted by GBAUTO
I was looking at the differences on the 09+ US models and the AUS market(I think they use the old 3 plug ignitor) and it looks like the difference on the pickup is that the early models have an isolated ground circuit(2 wire) for the pickup while the US models just use a single wire with a common ground circuit.
thanks, so would i be able to use signal wire alone on neutral switch or will i need to run other 2 and connect to appropriate place
Old Jun 23, 2014 | 02:11 PM
cmott426's Avatar
what is wrong with the 09 motor?
Old Jun 28, 2014 | 11:42 PM
dziuggy's Avatar
ran low on oil done
Old Jul 2, 2014 | 02:53 AM
coltfourfive's Avatar
Originally Posted by dziuggy
ran low on oil done
Sounds like a good excuse for a 351...
Old Jul 2, 2014 | 03:15 AM
MaximusPrime's Avatar
Use the '07 motor with the stator and cover from your bike? No wiring issues, just nuts and bolts...
Old Jul 6, 2014 | 06:12 PM
dziuggy's Avatar
yes that is the plan, however there will be 2 wires not used coming out of said sensor.
should have time this week to work on it ill update
Israel-klx250s
Mar 4, 2012 08:33 AM
Mart3971
Mar 24, 2011 06:56 AM
WestOzKLX
Apr 21, 2008 07:23 PM
fredhill032188
Jul 24, 2007 10:47 PM
