Klx 250 to 351
Old Mar 20, 2017 | 09:22 PM
Justin Davis's Avatar
Default Klx 250 to 351
Hey all, finally pulled the trigger and install a 351. Did not
Have this much noise racket from the engine before. I am
Still using the automatic tensioner looks fine but I have ordered
A manual one. Does this sound like it is the cause ?
Thanks!!
Old Mar 23, 2017 | 06:06 AM
timc63's Avatar
Make any progress Justin? I can't tell what i am hearing in your .mov file, sorry.
TC
Old Mar 23, 2017 | 07:06 AM
togenshi's Avatar
Most of the sound is from the intake. Yes and cam chain can be loud if not adjusted properly. Its widely known that the OEM auto adjuster is crap.
Old Mar 24, 2017 | 09:45 PM
No progress yet. Checked over the timing etc again everything
Looks correct just sounds a lot more rough in the valve train area
Hoping tensioner will fix the issue. On a side note it does run!
Old Mar 26, 2017 | 05:53 PM
LemonRX's Avatar
Did you do a valve check while it was apart? It sounds fine to me, remember that you're using more gas, and have a more powerful combustion that will make more noise.
Old Mar 26, 2017 | 06:08 PM
I did check the valves everything is in spec. Maybe I'm just being too paranoid. Have not had a chance to take it for a rip yet too much snow and gravel up here!
Old Mar 26, 2017 | 10:08 PM
durielk's Avatar
Just ride it till it blows!
mdragon
Sep 11, 2024 08:18 PM
kyrral
Jan 18, 2012 03:49 PM
kyrral
Feb 21, 2011 12:06 AM
teenycar
Aug 4, 2010 11:44 AM
