KLR Headlight in KLX? (2007)
Old Apr 30, 2019 | 10:19 PM
AZR's Avatar
AZR
Default KLR Headlight in KLX? (2007)
I saw this headlight kit and it's pretty much exactly what I've been looking for to replace my 2007 KLX stock headlight. It's just a plug-n-play headlight, square, should fit right in with no cutting etc. Also it's designed for LED so should be better than just sticking an LED bulb in the stock housing.
KLR650 LED Headlight Kit - JNS Engineering
(better picture)
https://www.rockymountainatvmc.com/p...eadlight-kit-p
The only problem is, it's for 87-07 KLR.
Does anyone know if the KLR headlight with fit in the KLX? The part numbers are different, 23007-1364 (KLR) vs 23007-1372 (KLX).
Old Apr 30, 2019 | 10:24 PM
Tacoma660's Avatar
only thing i could see that might cause an issue is the mounting points
Old Apr 30, 2019 | 10:29 PM
AZR's Avatar
AZR
Looks like the mounting bracket (23005-1052) and bulb (92069-005) are the same part number for both bikes.
Old Apr 30, 2019 | 11:04 PM
Tacoma660's Avatar
than should be good then
Old May 3, 2019 | 09:59 PM
Matt88-8's Avatar
Thats purdy!
Old May 3, 2019 | 11:33 PM
T_G_O_T's Avatar
Let us know how it works out for you.
Old May 4, 2019 | 07:15 PM
Haldor's Avatar
Agreed, that is the way to go. I did a bulb only upgrade on my KLR and it wasn't that great. I wonder if that would fit a 2018 KLX250?
I like that the housing is the heat sink, no fan to worry about.
neilaction
Jul 8, 2008 01:44 AM
neanderthaler
May 23, 2008 01:52 AM
Savagekilla
May 16, 2008 10:22 PM
WestCoast4Life
May 4, 2008 09:47 PM
batang city jail
Ninja 250R
Jul 26, 2007 10:50 AM
