Kenda 270 rear
Old 08-15-2013, 06:03 PM
JaMan's Avatar
Default Kenda 270 rear
I purchased a Zenda 270 rear tire in a 4.10-18 size. The description states Section width= 100, Aspect Ratio= 100, and Rim Dia.= 18. I was under the impression that the stock size is a 100/100-18. After reading several posts, it seems many guys are running 4.50, 4.60, and 5.10 sizes. Did I purchase the wrong size tire?
Old 08-15-2013, 07:59 PM
250sf09's Avatar
I think you have the right size because you have the s model. I run a 3.0 front and 4.6 rear on my bike but I have the sf so my rims are wider than yours. I think you are good.
Old 08-15-2013, 09:35 PM
795.0pacecar's Avatar
4.10 is going to be kinda narrow. I have a 4.50 on mine and it is perfect. Just slightly wider than the stock tire was.
Old 08-15-2013, 10:54 PM
ol'klx-er's Avatar
100/100 -18 is the way to go. If a tire has only 4.1, 4.6 etc., go by measured size, same outside diameter.
Old 08-15-2013, 11:05 PM
djchan's Avatar
anything wider than stock will noticeably affect our already suspect power.
Old 08-15-2013, 11:20 PM
ol'klx-er's Avatar
The OD, if bigger raises the gearing so the 13 up front is more like the stock 14.
I like my 100/100-18 Michelin AC-10
Old 08-16-2013, 12:39 AM
4.6 is an inch size the 100 is a metric size, they will both work, as long as the rim dia is right , 18 inch.
4.1 is 104 mm, so you are close. Many guys run 110mm wide tires , I like the 120mm wide tires. 4.6 = 117mm
Old 08-16-2013, 12:19 PM
JaMan's Avatar
ok, so it seems the tire might be a tad narrow but the tire will fit and should work fine. I certainly don't want to run a large tire that will rob some horse power. I'll look for a tire around 4.3 (110mm) in about 4,000 miles; hopefully Thanks everyone!
Old 08-17-2013, 01:28 PM
Jules083's Avatar
Let us know how you like it. I'll be due for a new rear before too long, have no idea what to get yet. I want the traction of a dirt tire with the wear of a street tire, like all of us. I'm between the D606 or the Kenda 270 I think.
Old 08-17-2013, 01:56 PM
Savage's Avatar
I like my 5.10 Shinko 244 rear.
Quick Reply: Kenda 270 rear
