Kenda 270 rear
Kenda 270 rear
I purchased a Zenda 270 rear tire in a 4.10-18 size. The description states Section width= 100, Aspect Ratio= 100, and Rim Dia.= 18. I was under the impression that the stock size is a 100/100-18. After reading several posts, it seems many guys are running 4.50, 4.60, and 5.10 sizes. Did I purchase the wrong size tire?
4.6 is an inch size the 100 is a metric size, they will both work, as long as the rim dia is right , 18 inch.
4.1 is 104 mm, so you are close. Many guys run 110mm wide tires , I like the 120mm wide tires. 4.6 = 117mm
ok, so it seems the tire might be a tad narrow but the tire will fit and should work fine. I certainly don't want to run a large tire that will rob some horse power. I'll look for a tire around 4.3 (110mm) in about 4,000 miles; hopefully Thanks everyone!
Let us know how you like it. I'll be due for a new rear before too long, have no idea what to get yet. I want the traction of a dirt tire with the wear of a street tire, like all of us. I'm between the D606 or the Kenda 270 I think.
