Kawasaki Ninja EX-250F throttle return
Old Jun 26, 2012 | 12:13 PM
jhoffy22's Avatar
Default Kawasaki Ninja EX-250F throttle return
Quick question. Should a crotch rockets throttle be quick to return to idle like our bikes throttle is? It has the same exact carburetor, just 2 of them from the looks of it. My friend broke down on the side of the road yesterday and it was a fuel issue and the throttle was very bouncy returning to idle and was not "snappy" like our bikes throttles are at all.
Old Jun 26, 2012 | 12:21 PM
stephenmarklay's Avatar
Yes it should.
Old Jun 26, 2012 | 01:50 PM
jhoffy22's Avatar
Originally Posted by stephenmarklay
Yes it should.
I thought so, he actually has the same bike as you have in your signature from the looks of it. 06 yellow ninja 250.
What is up with the two carbys? Have you been in there yet? I might insist that we pull it apart this weekend and give the carby a nice bath.
Old Jun 26, 2012 | 02:01 PM
Mine is the 500 but they are very similar. I had my carbs off a few weeks ago, cleaned them, drilled out the pilot screw covers set the float height etc. I also adjusted the valves.
The carbs don't need to be broken apart. You just leave them attached to each other and clean them.
Runs like a top now.
Old Jun 26, 2012 | 05:14 PM
Highbeam's Avatar
The throttle response on crotch rockets is faster. It is faster to rev and faster to return to idle. This isn't because of the carbs as much as the very lightweight flywheel.
Old Jun 26, 2012 | 06:41 PM
wildcard's Avatar
Carbs likely need to be cleaned or adjusted or both.
Old Jul 7, 2012 | 06:28 PM
mikesova's Avatar
lol @ calling the EX250 a "crotch rocket". I had one.
Old Jul 11, 2012 | 05:27 PM
Highbeam's Avatar
I didn't call the ex250 a crotch rocket, Jhoff did, I spoke about crotch rockets in general which I have ridden. Just not an EX250. Pretty weak?
Old Jul 11, 2012 | 06:50 PM
wildcard's Avatar
Compared to other sportbikes yes, but they have about 28hp and weigh about the same as the klx so they are pretty quick relative to other 250's. Problem is the power is up in the higher RPM ranges and they just don't have the low down torque of a KLX.
I would not trade my tarded 331 for a ninja 250, unless i was looking for a dedicated track machine. The KLX makes a much better street bike than the EX250 IMO, especially with a big bore.
kaybee
Dec 29, 2011 03:07 PM
nornalup
Jun 29, 2011 07:39 AM
OMalley912
Feb 15, 2008 09:54 PM
mmi86
KX250 & KX250F
Aug 26, 2007 06:48 PM
Finger Mullet
Feb 3, 2007 06:40 PM
