JUST WENT DOWN ON THE KLX ! Picture of Damage
Old Jul 4, 2013 | 12:08 AM
  #31
Originally Posted by wildcard
well... he probably doesn't' get many visitors in the old folks home.
They do let him drink his Bush Light there, but only if he finishes his strained peas .
Old Jul 7, 2013 | 06:40 PM
  #32
MikeW's Avatar
sucks to go down, been there done that
hoping this will help if that ever happens again
at least keep the shifter from poking a hole in anything
Old Jul 7, 2013 | 08:35 PM
  #33
zippets's Avatar
sure would hate for a branch to get stuck in those bars
Old Jul 8, 2013 | 01:34 AM
  #34
MikeW's Avatar
no branches on the streets
thats where I ride
Old Jul 8, 2013 | 04:14 AM
  #35
Karitane Pete's Avatar
so that's why its so clean
Old Jul 8, 2013 | 10:37 AM
  #36
zippets's Avatar
thats where I ride
then you shouldn't need it in the street
Old Jul 11, 2013 | 04:29 PM
  #37
SupaMoto's Avatar
I need your help guys !
I want to get my bike back on the road, I have ordered the new generator cover to replace the damaged one. But I do not know how to remove this tan colored circle thing inside of the cover to install onto the new one. I have the service manual but I'm not sure where to find this info. Any help ?
Old Jul 11, 2013 | 05:41 PM
  #38
If I'm reading you correctly, you want to remove the stator...the tan thing. I see 3 allen bolts in the pic that are holding the stator to the cover.
Old Jul 11, 2013 | 06:20 PM
  #39
SupaMoto's Avatar
Yes I would like to remove the stator and also the wire that is mounted on the cover to install it onto the new cover. I tried to loosen the Allen bolts and there was no sign on it lossening without feeling like I would strip or break the Allen key. So I'm thinking maybe that flat head looking center piece can be lossening from the front side of the cover because I see threads in the center. Also the wire is mounted on the cover and it has a silicone rubber type of adhesive that is sealing the edges of it stuck into the cover I guess for sealing it from weather water conditions. I will have to peel that off and when I mount it on the new cover I won't have the silicone type seal. I'm stuck lol I cautious to try to lossen these Allen bolts too hard.
Old Jul 11, 2013 | 08:20 PM
  #40
wildcard's Avatar
get a bit driver and allen bit on a rachet to remove the bolts ?
