JUST WENT DOWN ON THE KLX ! Picture of Damage
Old Jul 2, 2013 | 03:10 AM
Originally Posted by dan888
this is what the other side of your stator cover looks like
Actually I wrote that wrong, this is not what the other side of YOUR stator cover looks like, yours has a big F-ing hole through it. You gotta laugh about it, trust me I know
Old Jul 2, 2013 | 03:21 AM
Oil passage hole into crankcase, is at the bottom, below the crank. Maybe .500 round hole cast into crankcase. Not super easy for pieces to find their way through.
Old Jul 2, 2013 | 04:19 AM
250SM's Avatar
Have a look on ebay. I have seen a few on there.
Old Jul 2, 2013 | 04:23 AM
Good point, I got the one I have on my bike now for $15 on eBay. It had some damage but was useable.
Old Jul 2, 2013 | 04:30 AM
250SM's Avatar
Yea a lot of bargins but all in the U.S
Old Jul 2, 2013 | 02:23 PM
You know what...I think I'd pull the stator cover off, grind, file, and clean up everything at the punture. Then tape over the outside, forming the tape into the contours of the rest of the outside of the cover...kind of like a mold. I'd then use JB Weld from the inside and shape a good patch that doesn't interfere with the operation of the rotor or stator.
Or...you just pack JBW from the inside and outside and then carefully grind and file down the excess material after it dries. JBW when applied properly is pretty amazing. I've seen fixes last as long as the rest of an engine in some pretty critical places. Clean, effective application of the JBW is the key.
If this cover shows no other structural damage that would affect rotor/stator operation, I'd reuse it instead of buying a new one.
Old Jul 2, 2013 | 05:29 PM
SupaMoto's Avatar
Thanks for everyone's suggestions and info.
I am still very disappointed that I let the bike get out from under me.
I'm estimating 2-$300 to have it back to normal
Generator cover - $100-110
Shift lever - $50-60
Led taillight - $70
Rear turn signals -$?
Synthetic oil change - $20-25
Handle bars(maybe) -$100 +
I just plan to buy a brand new case cover rather then a jbweld fix or used one, so that it has a normal appeal if I decide to sell the bike. I'm a bit nervous to replace the cover my self but I will give it a shot. I may have some questions for you later on Dan, thanks.
Old Jul 2, 2013 | 05:33 PM
Originally Posted by Arctra
Part: COVER-GENERATOR
Part number: 14031-0110 (replaces 14031-1400)
Should be pretty easy part to replace
$136 from Part Shark (http://www.partshark.com/fiche_section_detail.asp)
Maybe time to invest in a bash plate?
102$ ronayers
Engine Cover(s)
Old Jul 2, 2013 | 09:40 PM
I'm going to keep this quote for the next time TNC calls ME a cheap ***. Geez TNC, bubble gum and bailing wire fix anything huh?
Seriously I know of a guy that has exactly what TNC just described. It was an emergency trail-side fix that he has just left as is. I know he has run it this way for a couple years without issue. Even though it has worked for him he is usually the guy that doesn't have any tools, or lets something wear out and holds up the ride while others attempt to get his bike fixed.
Old Jul 2, 2013 | 10:07 PM
No, no, no...you misunderstood. I was playing like it was me in his shoes and how I would handle it under those conditions. Dude!...I won't even eat French's mustard. It's Grey Poupon all the way, only.
