Just converted my s to a sf
Old 11-02-2014, 04:10 AM
MikeW's Avatar
Default Just converted my s to a sf
so as the title states just converted to the sf wheels
I noticed the rear sprocket is the same as my s wheel
I think it said 42
anyways from searching the stock sf sprocket is a 39
now the local shop I order from have them for $50
is that a decent price, or is there online sellers for less money
I am using a 15 counter sprocket that was to help lower the freeway rpm's which it did work good at
Im sure my freeway top speed will be reduced some with this gearing and smaller tire, just not sure how much
I did have a max gps of 86 mph before
if its not raining tomorrow im going to test before buying anything
I guess if you figure going up one size in front is the same as going 3 smaller in the rear
then my gearing may be the same as stock sf gearing
and is the kickstand different on the sf
mine works, but is not angled much, which acutally works out good as it give me more parking space in my garage
just makes it a little hard for me to get off the bike because its up so straight when sitting on it
now I could cut mine, weld the foot up higher but was just wondering if the sf used a shorter kickstand
it was raining too much to ride it , but I did get it around the block a couple times I could tell it turns sharper or faster
got my drd speedo healer programmed to read correctly too
Old 11-02-2014, 06:22 AM
GBAUTO's Avatar
https://www.denniskirk.com/jt/rear-s...d/8106339S.sku
With shipping you would probably be over $40 so it's not going to be much of a difference.
Old 11-02-2014, 06:27 AM
Richard Avatar's Avatar
My SF kickstand measures in right at 1 foot.
Old 11-02-2014, 12:46 PM
MikeW's Avatar
no thats a good price even with shipping
because my store I would need to pay tax, and pick it up
so having it delivered to my house for around $10 cheaper why not
Old 11-02-2014, 12:49 PM
MikeW's Avatar
Also ordered this tail bag
to replace my larger carrier want to change up the looks of the bike a little
plus I can still always attach the larger carrier when needed and have good room with the smaller bag
Old 11-02-2014, 03:05 PM
MikeW's Avatar
came with a red front fender so I plasti dipped it
but im going to order a white one
Old 11-02-2014, 07:02 PM
MikeW's Avatar
mine is 14 inches
so guess they do come shorter
Old 11-03-2014, 04:49 AM
2007 Green Machine's Avatar
Looking good!
Old 11-03-2014, 01:11 PM
MikeW's Avatar
so as I thought I lost about 4 mph top speed on a quick test
and higher rpm on the freeway because basically im back to the stock gear ratio
So once the new sprocket comes in I should be back to my normal rpm I grew used to
get a little more out of the bike before shifting, I noticed I hit the limiter alot now
nothing strange on how it handles, I like it
and I like how its a little lower too, since im used to riding small scooters
too bad they didnt have this model at the store when I bought my bike probably would of got it
Plus I like the fact I can swap out the wheels easily
Old 11-03-2014, 03:23 PM
Illking's Avatar
Looks great mike!
Quick Reply: Just converted my s to a sf
