Just bought 2009 KLX250S, help identify 'mods' please
Old Nov 7, 2014 | 09:18 AM
Klxster's Avatar
Get up in that EFI and find some place to put those jets.. and that big drill bit..
Replace the CD with a 45rpm Vinyl Single - Say "Rock Around the Clock" ..
Mopowa!
Just Kidding.. Couldn't resist..
Old Nov 7, 2014 | 10:40 AM
45 has a bigger intake than a CD...
Old Nov 7, 2014 | 10:11 PM
Richard Avatar's Avatar
Or this:
Old Nov 7, 2014 | 11:18 PM
MaximusPrime's Avatar
Originally Posted by Richard Avatar
That is hilarious! Especially the submarine.
Old Nov 8, 2014 | 07:00 PM
willb's Avatar
From: Cheshire, in between the Welsh hilly bits and the Peak district hilly bits - just about in the North
1.0 assuming it FI - short out terminals 1 & 3 on the clutch lever inhibitor switch - this will remove the Rev restrictor in gears 4,5 & 6. 2 Min job I have done 7,000miles like this no issues. You can get fancy with upgraded FI units but consider reliability - see lots of info on the forum.
2.0 Decent bash plate - I have a Scorpion from Canada does the job
3.0 Foldy mirrors - saves a break in a spill
4.0 Tyres - the original Dunlops are OK on the road but you can do better for un-made surfaces
5.0 13 Tooth sprocket - better (lower) gearing for tricky stuff - but you lose higher speed on the road
6.0 Headlamp - not the best, a couple of cheapish LED spots {fixed to the Fork leg clamps on my bike} make a big difference
7.0 Seat - gets a bit uncomfy on long runs
8.0 Tank - 110 miles range
9.0 Chain oiler - i use a Tuturo unit cheapish and simple
10.0 Tool bag - the little standard one is a bit small
Adverts on bikes - i am not sure why either unless someone is paying, but each to is own. And what's wrong with green?
Enjoy the trip
Will
Old Nov 8, 2014 | 07:04 PM
willb's Avatar
11.0 Take the footpeg rubbers off for better grip
12.0 Hand guards and leave the lever clamps not to tight - save your levers in a fall. and maybe buy spare set of levers and clutch cable.
13.0 lots of cable ties - they fix anything.
carrgti
KLR250
Nov 12, 2012 08:49 AM
dawg2009
Feb 27, 2012 12:59 PM
Lawnica1
Aug 14, 2010 06:37 AM
boo727029199
Sep 20, 2008 03:25 AM
Ishtta
Aug 21, 2008 12:20 PM
