Jetting for Dum....I mean jetting explained..
Old Dec 2, 2010 | 02:17 PM
Originally Posted by b_joannblue
When you install one of my big bore kits (B&B Cycle Restoration) I send a fresh air blockoff plate with the kits. If you seal & install it correct this will stop the deceleration popping in the exhaust. When using the stock carb you need to increase the pilot jet one size larger & two sizes larger on the main jet. these numbers are above the jetting that you were using before installing the 351 kit.
What fresh air is being blocked with this blockoff plate? Is this the smog circuit, or something else? Thanks.
Old Dec 2, 2010 | 04:30 PM
David R's Avatar
Smile
IDRIDR Yes its the smog circuit.
As far as jetting I look at as more of a "Season to taste" .
David
trev0006
Jun 22, 2011 03:30 PM
Worlok14
Jan 7, 2009 01:09 AM
Nobrakes
Sep 26, 2008 01:30 AM
pie4foou
Jan 30, 2008 01:55 AM
DevilGirl
Sep 6, 2007 03:43 PM
