jet options for 2006 klx 250s
Old 08-03-2012, 02:09 AM
urk2010's Avatar
Default jet options for 2006 klx 250s
first time member here....quick question and need quick answer....i have a 2006 klx 250s bought an fm powercore4 slip on for it...obviously need a rejet, but dynojet doesnt make a kit for 2006 year...starts at 09...will an 09+ dyno kit work for my 2006? wat are other options?
Old 08-03-2012, 02:31 AM
djchan's Avatar
IIRC, you can use the DJ kit for the 2006 KLX300. Other than the cc's - all's the same. For that matter, I don't think the carb or engine is different between the 06 and 09 models. Bet they're the same.
Don't trust me on that though, I went with the Keihin jets and N1TC needle cause I already had them laying around.
Old 08-03-2012, 02:35 AM
System6's Avatar
Welcome to the forum and congratulations on your bike. I have the same year KlX250.
There are many options for jetting. I think I bought the KLX300 DynoJet kit, can't remember.
I ended up going with the DJ 120 main, the DJ needle. My bike runs great but, most guys go with a larger main.
Check out the FAQ in the sticky section. There's lots of good info there with many links. Lots of great people here to help you out.
Old 08-03-2012, 01:23 PM
urk2010's Avatar
Thanks guys....i already have an 09+ Dynojet kit i culd use but i dont wanna open it up if it wont work
Old 08-03-2012, 02:18 PM
System6's Avatar
Just go onto the DJ site and see if your numbers match the kit for a KLX300.
Old 08-03-2012, 02:21 PM
The jet kits you're looking at are slightly different. I too used the KLX300 kit (DJ #2206) on my '06. But I recall others around here using the 09+ kit on the older carbs. Look up the instructions and parts list on line to see what is different. The needles have different part numbers and I'll be there's a "little" difference between them. Give dynojet a call or email if you're not sure.
Old 08-03-2012, 09:53 PM
urk2010's Avatar
the 09klx 250s has every main jet the klx300 kit has....only differences in parts list is 09 has a 228 needle and the klx300 has a 352...the 09 also has a slide spring where as the 300 kit does not...i have never messed with a carburetor before, is that needle gonna make a night and day difference or do u think the 09 kit will work?
superman
07-03-2013 11:54 PM
stephenmarklay
03-25-2012 04:02 AM
C0bRSV53
04-02-2007 11:34 PM
Joe67
11-16-2006 02:23 AM
robdandrea
11-04-2006 11:17 PM
Quick Reply: jet options for 2006 klx 250s
