installing new handle bars. Do i need to drill a hole in them
Old Nov 5, 2012 | 08:34 AM
duff's Avatar
thanks for the quick response. Going to cut the plastic locking pins tomorrow
Old Nov 5, 2012 | 03:58 PM
drm's Avatar
drm
A wrap of cloth tape on the bar will keep the controls from slipping around.
thats a good idear
Old Nov 5, 2012 | 03:59 PM
drm's Avatar
drm
Originally Posted by djchan
I like my controls to slip just a bit. Fewer things get broken off that way.
but then i hit my horn when try to turn
Old Nov 6, 2012 | 04:21 AM
djchan's Avatar
You may have it a bit TOO loose.
Old Nov 6, 2012 | 06:09 AM
1250FAntom's Avatar
Ground off the pins and used a wrap or two of electrical tape to give some purchase to the controls, has worked just fine on a few bikes. Adding a hole will just add frustration when you decide to change the angle of the bars and want to tweak the position of the controls.
Old Nov 6, 2012 | 06:30 AM
^ yup!
Old Nov 6, 2012 | 11:18 AM
grahamgower's Avatar
Originally Posted by JoelThailand
I did the unthinkable & drilled my Zeta fatbars!!
I'm hoping that these tiny holes i drilled don't compromise the strength of my bars......but i hated my switches moving/spinning on the bars!! After 8 months all is good...
Your choice Duff
Hey Joel, did you have to change anything, like mounts, to fit the fat bars. What about all the controls made for standard bars, how do they fit the fatties?
Old Nov 7, 2012 | 08:52 AM
JoelThailand's Avatar
Hey Graham, you will need some new bar clamps for the fatter bars! The UX3 clamps also raise the bars by 1.5"inches which I like. I went for Zeta Motard medium bend bars.....They are a little wider & little more forward than stock!! For me as a tall man with long arms, this riding position is fantastic for me.
To answer your question, the bars are only fat in the middle & at the bends...for extra strength....they also look better than stock. The end of the handlebars tapers off to the original size, so all the grips & controls work/fit the same as stock.
Old Nov 8, 2012 | 09:01 AM
Thanks Joel
As usual a proffesional reply with cool pix. So its off to shop I go, I owe, I owe.
RayTard
Oct 25, 2011 01:50 AM
brownie2
Mar 15, 2011 03:41 PM
maineack bob
Apr 22, 2009 09:11 PM
horizonod
Dec 14, 2008 01:21 AM
Joe
May 4, 2006 12:00 AM
