Ignition coil primary peak voltage
Old Oct 18, 2018 | 03:16 PM
RimBender's Avatar
Seen bad plug caps cause those symptoms . Either carboned up on the plug connection, or poor connection where the cap screws onto the wire, or a burnt out resistor.
Old Oct 18, 2018 | 09:38 PM
klxnoobie's Avatar
I checked plug cap its reading 5k and I've got continuity through the wire so connections are good.
Old Oct 20, 2018 | 05:14 PM
peabrain's Avatar
i once had a bad spark plug causing problems as rpm got higher (was a new plug even)
Old Oct 20, 2018 | 06:07 PM
klxnoobie's Avatar
Well got new coil and plug cap on order so it's a wait and see what happens.
Old Oct 26, 2018 | 06:17 PM
klxnoobie's Avatar
Found out what was causing my engine stumble. I had changed the headlight to an H4 led bulb and thought well I've tried everything else. So I disconnected the light took it for a run down the street and no engine surge or stumble. I put the old stock bulb back in and it runs like a champ. I switched between the two bulbs a few times just to make sure the problem did repeat itself and the led is definitely the source. I called tech support for the company I bought it from and explained the issue, of coarse they've never heard of one causing a problem like this. They didn't deny that it wasn't plausible either and hat's off to tech support are going to help getting it resolved.
Old Oct 26, 2018 | 09:23 PM
Brewster's Avatar
NEVER would have expected that! Good catch.
Ride on
Brewster
Old Oct 26, 2018 | 10:38 PM
klxnoobie's Avatar
Tech support called me earlier this afternoon and they've already got a replacement in the mail. I'm impressed with their customer service. Probably have on Monday so we'll see if it repeats itself.
Old Oct 26, 2018 | 11:39 PM
RayCour's Avatar
So surprising!... I guess that LED bulb has switching electronics to regulate the led current, resulting in switching spikes that couples into the crankshaft sensor circuit. Said coupling might occur only with a defective led electronics or a missing ground in the harness.
I'm eager to see how your bike runs with the replacement bulb, keep us informed!
Old Oct 27, 2018 | 01:06 PM
klxnoobie's Avatar
I'm thinking there might be an issue with the PWM controller. Maybe it wasn't shielded properly. When I get the new light I'll be sure and post the results.
scubiedoo22
Jul 17, 2019 05:17 PM
rjmiller0751
Classic Sportbikes
Nov 20, 2014 07:49 PM
sabaugebenz
Oct 2, 2014 11:33 AM
flateric
May 19, 2011 10:32 PM
ndspectre550
Oct 8, 2008 01:53 AM
