Was I running rich?
I went went with the #128 and drilled the slide. Put in the dynojet needle 3rd clip (with the two small spacers on top-- did you guys use these?) Also installed the kouba screw at 2 turns out right now.
I cleaned the sealant off as well as I could and put it all back together. Just got back from a quick ride and it was running well. Its the first time I've hit the rev limiter since I've had it. It seemed to rev in the higher rpms better
I read as much info as I could find, before re-jetting mine. One trick I ran across was to drop the diaphragm in a cup of HOT water as soon as you remove it, to keep it from expanding. Worked for me.
I'd be worried if I found sealant in there... might be a good idea to clean the surfaces and just install a new diaphragm. You don't know if the PO drilled it or not... My '09 DynoJet kit came with a new spring, and did NOT tell me to drill the hole in the diaphragm.
My elevation is right around 1000ft.
I turned the fuel screw in to 1 turn to lean it out a bit and see how it ran. I was getting alot more decel pop. When I put in back at 2 turns out the extra decel pop went away. I'm thinking this is right around where I need to be
