I WAS going to get a 331 kit until.......
Old Apr 10, 2012 | 11:06 PM
2veedubs's Avatar
3/8 drive torque wrench that reads in inch pounds is very handy for big bore install.
Old Apr 10, 2012 | 11:14 PM
wildcard's Avatar
Originally Posted by adrian2779
Im hoping to convert mine shortly.. (waiting for the piston!).
Telescopic magnet ...check,
Torque wrench.. check,
Any other tools recommended apart from the regular stuff? For example some pistons are removed/fitted by a special tool. Is one needed in this case? What was the most difficult/challenging stage so i have a heads up?
Worst part for me was probably getting the piston into the cylinder, i cheaped and didn't buy a ring compressor so i had to improvise and make one out of a soda bottle and a zip tie.
Originally Posted by durielk
Be sure and get a low range torque wrench!
If you are not mechanically inclined the your only paying the shop a couple of extra hours labor, which is $170 extra. Guess what, that is nothing if it gets screwed up. It is a lot more complicated than changing a plug.
Make sure your torque wrench will go as low as 60 in-lbs and as high as 40 ft-lbs and you will be all set. Of course my in-lb didn't go high enough and i seemed to recall the torque specs being lower so i had to but another torque wrench to fasten the head back down.
Old Apr 10, 2012 | 11:20 PM
2veedubs's Avatar
The valve cover gasket was the worst part for me. I really dislike that piece of rubber.
Old Apr 11, 2012 | 04:02 AM
drm's Avatar
drm
That's what she said...
HA....someone had to say it.
Old Apr 11, 2012 | 04:41 AM
2007 Green Machine's Avatar
I have seen this said many times. Why is it a PITA? I'm getting ready to tear my bike down this weekend, and hopefully be putting it back together in about a week or so when the 351 gets here. I've had my valve cover off my 87 kawi mojove 250 many times and had no problems with it.
Old Apr 11, 2012 | 04:44 AM
ol'klx-er's Avatar
Seems there was a bad batch of cover gaskets that would shrink once they were taken off.
Old Apr 11, 2012 | 04:48 AM
Well, that sure don't sound like fun. I guess I'll find out very soon.
Old Apr 11, 2012 | 03:48 PM
  #28
I was expecting this problem with mine, but no issue at all. I wondered what I was doing wrong when it installed so easy
Old Apr 11, 2012 | 04:15 PM
  #29
ol'klx-er's Avatar
I think it was '09s -> that started having that issue. You know: "New and Improved".
Old Apr 11, 2012 | 04:18 PM
  #30
the front cam chain guide was a real pain for me.... took me 20 mins to get it back where it belongs.
I painted the cams and chain so i know where it went.
