How to: KCA removal on 09 KLX250S-California model
Old Aug 15, 2008 | 01:19 AM
jpaul310's Avatar
Default How to: KCA removal on 09 KLX250S-California model
I completed the free mods on my 2009 KLX250S California model and I thought it would be a good idea to do write up on how to remove the smog crap on the 09 CA model. First of all, let me thank everybody here for all the helpful information you guys have posted! I couldn't have done this without you guys! I have never done a write up of any sort so bare with it. I did this mod to clean up the engine compartment and for reduced exhaust temperature. This does not do anything performance wise. Please excuse my dirty bike! I made sure that no dirt got inside any of the parts I took off.
Tools needed: 8mm socket
10mm socket
14mm socket
socket wrench
needle nose pliers
flat head screwdriver
maybe a breaker bar for the front engine mount bolt and screws
Parts needed: 2 packs of assorted rubbercaps from autozone
6ft. 7/32 rubber hose
This is what comes off...
Start by unplugging the hoses that's connected to the airbox
unplug the hose with round piece connected between the header and valve cover
Remove the canister and the canister shield using a 14mm socket to remove the bolts.
Remove the two 8mm bolts and remove the small canister...
Remove the two hoses connected to the carburator. This picture is after I plugged it up. Sorry no picture before.
So this is what needs to be plugged up...
Two outlets on air box
Outlet by exhaust header
Two outlets on carburator
Make 2 vent hoses for the fuel tank red and blue vents. There should already a hose for one of the vents so you only need to cut 2 hoses.
Run the vent lines to the rear shock...
This is what it looks like after...
After doing this mod, be aware that when you overfill your tank, you will see fuel dripping from one of the hoses. This mod made it easier to pull the fuel tank off.
File Type: jpg
Old Aug 15, 2008 | 01:33 AM
WestOzKLX's Avatar
Nice write up. PITA for all Californians though.
Old Aug 15, 2008 | 06:49 AM
RaceGass's Avatar
great job.
someone needed to do it
Old Aug 16, 2008 | 07:28 AM
punkenduro09's Avatar
good post, ill keep this one for when i get around to mods.
Old Aug 17, 2008 | 10:49 AM
chris72a's Avatar
Default Re:
Good work and nice writeup, you sure do get some extra crap over there..
Cheers
Chris.
Old Aug 17, 2008 | 11:47 PM
LearjetMinako's Avatar
Is it illegal to remove the smog crap, espacially for CARB states?
Either way, good job.
Old Mar 15, 2012 | 07:00 PM
rgoers's Avatar
Appreciate the well-written instructions!!! I will be getting rid of my extra smog stuff this weekend!
Old Mar 16, 2012 | 12:34 PM
linkin5's Avatar
Sure it's illegal.
Old Mar 16, 2012 | 12:39 PM
Originally Posted by linkin5
Sure it's illegal.
hahaha, and I am placing a copy of this in the DIY section. Nice write up.
Old Mar 16, 2012 | 01:09 PM
Keep you eye on all those rubber plugs, they dont last that long, get dry and crack.
