HMF Muffler Broken In?
Old Nov 14, 2007 | 05:00 AM
Default RE: HMF Muffler Broken In?
ORIGINAL: DJFields
This was ACTUALLYproduced specific for an exhaust application.
The suggestion was for a packing the lasts not about being cheap !
hahaha or does not weigh a ton!
Old Nov 14, 2007 | 09:41 AM
ORIGINAL: klx250s_rider
Thanks Eric, I'll check into it!
great products, your welcome.
on the "metal shavings" for repacking.... umm....yea.... that sounds like a really bad idea, metal shavings from doing machine work and stainless steel "steel wool" for repacking is ALOT different.
Old Nov 14, 2007 | 10:32 PM
kawikathy's Avatar
All those loose shavings? Sounds like it could get into the combustion chamber under the right conditions.
Old Nov 15, 2007 | 07:07 PM
millman's Avatar
I would be concerned about shavings getting in the cylinder also or I wonder if they could get shot out of the exhaust like a projectile.That could really suck to get a peice of metal shot in your eye or other body parts.
Old Nov 15, 2007 | 07:42 PM
ZX1100F1's Avatar
Why are we even having a discussion about using metal machine shavings when packing is so incredibly inexpensive?
You also would not want to use any type of steel wool without it being insulated between fiberglass matting from touching the aluminum or stainless silencer as dissimilar metals and heat are a bad combination for promoting corrosion.
Old Nov 15, 2007 | 11:11 PM
Beardoge's Avatar
Really, come on now! Wrap it up and send it back to HMF like it says in there website and they will repack it, repolish it, and rivet on a new HMF plate on the side of it for 20 bucks!!!
Mine has 2700 miles on it and it has lost the deep throated cool sound it had, It's louder now and kind of ratteley sounding so mine is going back in the spring..
DJFields
Aug 5, 2010 02:54 PM
Dready
Sep 24, 2009 07:28 PM
RubberxSidexDown
Ninja 500R
Jul 24, 2006 08:11 PM
trey
May 29, 2006 11:35 PM
chrisrigas
Apr 27, 2006 03:55 AM
