High Bend Bars
Old May 25, 2010 | 12:51 AM
bootmud's Avatar
Default High Bend Bars
Does anybody know if there is enough cable lenth to install the Pro Taper high bends on a 09 klx250s?
Maybe I should have asked before I ordered them...
Old May 25, 2010 | 01:14 AM
tucaz#2's Avatar
a lot of people swear that they have plenty of cable i think they are all pre 09 though.
i replaced bars with some moose racing chepos that are close to stock and didnt see any cable slack at all.
let us know..
Old May 25, 2010 | 04:34 AM
punkenduro09's Avatar
kx highs, yes, but just enough. anything higher you need a longer clutch.
Old May 25, 2010 | 05:37 PM
jacksonriding7's Avatar
From: In North Western Jersey, but from Jackson, WY Originally
I also did a moose bar with a 1" Riser and had no trouble with fit, changing it also made installing my moose bark busters much easier as well. Stock was a disaster trying to install them because of the little cross bar and locations of bends and such.
Old May 26, 2010 | 01:02 AM
GaryC's Avatar
I just now finished MY hi bend bar installation and yes,,, barely fits is a good answer.
Play with the clutch until it's right. I can turn lock to lock and not have the clutch arm move. It does get tension but doesn't move. Well,,,,, maybe a smidge,,
Hopefully you bought grips because you will need to cut the stock ones off. AND,, gasgacinch is a great grip glue!!!!!
Old May 26, 2010 | 01:42 AM
hogzilla's Avatar
CR high bend and there is BARELY enough room. There is a tension with the bars turned to the left. It moves the clutch arm a smidge. I tried to find slack and there isn't any so I will live with it for a while. If there are problems I will change the cable.
Old May 26, 2010 | 03:37 AM
one question i get a lot is where i got the longer clutch cable, and that motion pro. they have a part on there site for custom cables and once you open it, its really simple to order. also, ive found the best grip glue is a good strong hair spray, like the stuff you used in the 80s (man i wish i could have live threw that era). gasgacinch probally works wonders also. i now use wire to hold the grips also and get a lot more use out of them now.
Old May 26, 2010 | 02:00 PM
I should have mentioned, my bike is an 07, so apparently my ease and slack with a small riser wont apply to you. One other nice thing about the moose bars, was that they are slightly narrower than stock too, a little bonus in the local tight trails. Now I'm about an inch less likely to need my bark busters
Old May 28, 2010 | 01:26 AM
redpillar's Avatar
I just ordered a spare clutch cable and both throttle cables all 2"longer from Motion pro, thanks for the info Punker!!
Old May 28, 2010 | 02:07 AM
Thanks for the tip! My grips are getting worn, and they're all twisted up on the bars. I need to look up the wire method too for the next set.
CC_Rider
Nov 29, 2013 06:50 PM
toastybake
May 18, 2011 08:17 PM
Nobrakes
Nov 21, 2010 05:20 AM
GaryC
Jul 12, 2010 10:46 PM
WestOzKLX
Dec 5, 2008 06:00 AM
