Help needed - 351 starting issues. Free Beer!
Old Oct 7, 2014 | 09:21 PM
Richard Avatar's Avatar
Have you tried jump starting it from your car battery etc?
Old Oct 7, 2014 | 09:47 PM
Michaelb2's Avatar
OK, so the word "su****ious" is being blocked because it contains for letters in a row that might be a racial slur. Sus-pic-ious. There.
I know that feeling of wanting to ride. I'll check the video tonight.
Old Oct 7, 2014 | 10:34 PM
Brewster's Avatar
Measure the voltage across the battery terminals while cranking it over. Then measure the voltage from the chassis to the terminal on the starter while cranking it over. The readings should be close. If not, you have an electrical problem. If the voltage at the battery drops below 10 volts, either the battery is weak or there is excessive load when the starter is engaged.
Have you rechecked the timing of the exhaust cam? The ACR should reduce the needed cranking force.
Ride on
Brewster
Old Oct 7, 2014 | 10:44 PM
durielk's Avatar
Originally Posted by Brewster
Have you rechecked the timing of the exhaust cam? Brewster
Exactly how do you do that?
Old Oct 7, 2014 | 10:58 PM
Brewster's Avatar
This will give some information:
KLX Valve Adjustment
Ride on
Brewster
Old Oct 8, 2014 | 12:12 AM
durielk's Avatar
OK, that is how to check the valve clearance. Why & how could his exht cam get out of time?
Old Oct 8, 2014 | 12:23 AM
Brewster's Avatar
From the provided link:
"Note the position of the cams. The lobes of the intake cam should point aft. On the cam gear you will see a small line next to the letters "IN". This line should be parallel to the to top of the head. On the exhaust cam the cam lobes point forward and the line next to letters "EX" should be parallel to the head."
At some point, the engine was torn down to put the 351 barrel on it. No mention of when this was done in relation to the current problem.
Ride on
Brewster
Old Oct 8, 2014 | 02:48 AM
Old Oct 8, 2014 | 02:57 AM
Satonic's Avatar
I have had a new battery and tried with other batteries. It's been running and starting fine for a couple of years until this slow cranking has gradually started.
I will get a multi meter today and report back with my findings. I was thinking it may be something to do with the ACR too.
Old Oct 8, 2014 | 03:37 AM
durielk's Avatar
I assumed it was running fine after the 351 work, otherwise I believe he probably would have mentioned that fact.
That being the case, after the motor was running properly, why would the exht cam suddently gone out of time? The same could be said for the intake cam, maybe the carb is on backwards, piston rings are reversed, etc.
