HELP! BIKE STALLING AT IDLE WHEN I GIVE IT GAS
Old May 28, 2008 | 01:25 AM
oldphart's Avatar
Banned
Default RE: HELP! BIKE STALLING AT IDLE WHEN I GIVE IT GAS
First of ditch the kdx snorkel. Your base line settings should be 128 main, clip #3 from the top stock pilot and 2.5 turns out on the mixture. Also I would replace your spark plug, I know they say they are good for a gazillion miles, but I have seen many a hundred thousand plus dollar cars come in on the hook with fouled plugs. And it sounds like your plug has taken a beating. My two cents worth hope you find the problem.
Old May 28, 2008 | 12:14 PM
123FU's Avatar
I HAVE DONE ALL THAT WITH THE EXCEPTION OF THE AIR BOX. BUT I DID NOT END UP REMOVING THE AIR BOX BECAUSE THE PLUG LOOKED ON THE LEAN SIDE. AND WITH THOSE SETTING I WAS IDLEING EXTREMELY POOR.
Old May 28, 2008 | 01:37 PM
oldphart's Avatar
Banned
vaccum leek ? did the t mod and found the rubber plugs to be less than add.
preload
May 24, 2021 02:58 AM
JeffNY
Oct 13, 2011 11:20 PM
Bas2thesem
Mar 30, 2008 04:55 AM
Mr.S7
Nov 21, 2006 12:45 AM
Forumsnow46
Sep 22, 2006 09:01 PM
