Help!!! After mods, bike wont start??
Old Apr 15, 2009 | 05:46 AM
Hey, give this a try and then report back.
1 turn off the gas
2 Drain the carb bowl
3 open the gas
4 start the bike....and yes it will start
Old Apr 15, 2009 | 02:33 PM
Mudhore's Avatar
+ 1 on daining the carb bowl...Sounds like you might have a plugged jet or just have bad gas in the carb...Good luck man
Old Apr 15, 2009 | 02:43 PM
My bet is on bad gas....that is if was a betting man.
Old Apr 15, 2009 | 05:12 PM
roadglider's Avatar
Did you disassemble the carb or remove and reinstall the stator or the cams? Like said above remove the air filter, open the throttel, and using a squirt can shoot a little bit of fresh gas straight into the throat of the carb. If your sure you have spark and you haven't messed with the engine or carb, and it ran fine before you did your mods it should at least start and run briefly. What temperature are you doing all of this is it really cold? If it is follow Deej's suggestion these things can really be a pain to start if it hasn't run for awhile and it is cold out. Good luck
Old Apr 15, 2009 | 05:16 PM
roadglider's Avatar
P.S you should drain the float bowl and shut the gas off before you do what I mentioned in the above post. If the float bowl is full of stale gas it may prevent the bike from starting even when you shoot gas straight into the carb.
Old Apr 21, 2009 | 11:51 PM
IQOUTLAW's Avatar
Default Update!!!!!!!
Sooooooo...
I finally got the bike running late last Wednesday nite.
It must be a problem in th ecarb o gas becasue when I tried teh starting fluid in the carb, I was able to get t he bike to start and run beefly.
The bike is now at the dealer to get jetted and hae a few other things done that I didnt want to do on my own.
Thanks for all of your help.
I will post some pics as soon as I get her home and all cleaned up!
Thanks again,
MAXX
Old Apr 22, 2009 | 12:20 AM
Mudhore's Avatar
glad you could get it started. good luck and hope you get it back soon.
nathbailey
KX125
Jun 16, 2016 01:35 AM
phil7mustang
Oct 10, 2011 04:09 AM
Lawnica1
Aug 14, 2010 06:37 AM
mzs6
Ninja 500R
Apr 15, 2008 09:22 AM
Toddy
Apr 19, 2006 12:01 AM
