Help!!! After mods, bike wont start??
Old Apr 14, 2009 | 06:02 AM
niven's Avatar
Banned
Fouled plug by the sounds of it. All this new platinum ,mechscrewium dont mean crap, just like yer weedeater change the plug fresh gas and there ya go.
Old Apr 14, 2009 | 06:52 AM
niven's Avatar
Banned
Hopefully, ya got air/fuel /compression at the proper time/ after 50 years of bull****.Try a new plug.
Old Apr 14, 2009 | 07:17 AM
niven's Avatar
Banned
Default run
Originally Posted by SlapDrum
Yup. All these are good.
My check list is Fuel, Air, and Spark. These three should make it go.
Missing compression my man, fuel,air spark,good bbq.No worries
Old Apr 14, 2009 | 07:27 AM
BP88's Avatar
Right, but what has the OP done to his bike to mess with his bike's compression?
Old Apr 14, 2009 | 07:49 AM
niven's Avatar
Banned
fuel air compression/ timing
Old Apr 14, 2009 | 07:51 AM
niven's Avatar
Banned
If no comp your a wet fart
Old Apr 14, 2009 | 08:06 AM
niven's Avatar
Banned
go back to basics . you need intake /exhuast. don't be poring raw gas on rare steak. God only knows, ets help him. missing compression and why I have seen people line up ring end gaps on major thust faces and wonder why oil is blowing out the *** end
Old Apr 14, 2009 | 08:19 AM
niven's Avatar
Banned
Brendan.c check out rmdra.ca
Old Apr 15, 2009 | 02:32 AM
IQOUTLAW's Avatar
So today after work I got back on it! I tried checking everything listed. I didnt make any mods or do anything to mess with my timing, so that should all be fine.
I started by checking the spark, I pulled the old plug and replaced it with a fresh one, held it against some metal and I do have spark.
I removed my new air filter and checked to make sure I had nothing behind it blocking the intake and as I suspected, it was clear.
I then checked all fuel lines coming from new tank. All lines looked and felt good but to be sure, I unplugged the line from the bottom of the on/off/res. valve and then opened it, fuel went everywhere. SO all lines are free flowing.
I then drained the fuel out of my tank and put about a gallon of fresh gas in. STILL NO LUCK STARTING!!!
I removed th eexhaust and checked to make sure nothing was blocking that, all clear.
I then tried unplugging the new headlight thinking it may be drawing too much power. Still nothing.
After trying and trying and tryign and th ebike just cranking and cran king, I finally got somethign. The bike backfired!!!
THAT WAS THE EXTENT OF IT!!! MY BIKE STILL WONT START!!!
ANYTHING????????????
Thanks, MAXX
Old Apr 15, 2009 | 05:16 AM
c_m_shooter's Avatar
Give the air cleaner a shot of starting fluid. If it starts for a few seconds and then dies, it means you let it sit too long and will need to clean the carb jets.
