Headpipe is too hot after mods & other crap!
Old Aug 23, 2010 | 09:38 PM
brownie2's Avatar
My 125 main is a Keihen part not a DJ
Old Aug 24, 2010 | 01:56 AM
RimBender's Avatar
vs. the small round K jet in this application, the DJ part fuels about the same. Not true with all K jets.
A common concern you see on many forums is the pipe glowing red hot usually seen in a dark garage. Nothing out of wack , just thin wall pipes vs. the double wall and chrome pipes people are used too. Can't say I've even seen my klx red hot though, but they have discolored.
Old Aug 24, 2010 | 03:05 AM
brownie2's Avatar
OK. I've decided that the headpipe isn't that big of a deal.
I wonder why I need to give it throttle to start after it's hot?
What does moving notches on the needle mean compared to larger main jet?
I'm thinking with the needle raised one notch it may have more fuel on starts. I haven't got to pull the carb yet.
Old Aug 24, 2010 | 04:35 AM
c_m_shooter's Avatar
Raising the needle won't affect starting. The needle controls from about 1/4 to almost full throttle. Main jet contols wide open. The pilot jet and fuel screw control idle to where the needle picks up.
Old Aug 27, 2010 | 03:02 AM
punkenduro09's Avatar
Originally Posted by BigSky KLX
I don't know much about the headpipe heat problem, but my bike has the same "give it a little throttle to start" problem since the mods.
im the same, but i dont see the throttle issue as a problem really.
Old Aug 28, 2010 | 06:34 AM
wynn711's Avatar
I wear MX Pants and the heat from the exhaust comes through the pants and I have to lift my leg out to get some air from time to time. I would not dare ride with shorts unless you are just in your backyard going no where!
Lawnica1
Aug 14, 2010 06:37 AM
Finger Mullet
Jul 30, 2008 09:21 PM
aszrael1266
Jun 19, 2007 03:37 AM
bryantjt
Aug 29, 2006 02:43 AM
kwninja88
Aug 22, 2006 12:59 PM
