headlight
Old Dec 28, 2019 | 08:05 AM
Jack Dysart's Avatar
Default headlight
I got a 2018 klx250 efi us version and wanting to get brighter bulb as the stock headlight on my bike are pretty terrible. Is there any simple bulb replacement that somebody has that is brighter than stock and only requires swapping bulbs? Thank you So much
Old Dec 28, 2019 | 12:10 PM
Tacoma660's Avatar
any led bulb would work but since its not a projector housing, you are going to get a lot of scattering
Old Dec 28, 2019 | 06:15 PM
It runs an H4 60/55 watt stock. You could do a hotter bulb too - H4 Halogen 100/55 watt. Technically the 100 watt is illegal in most places, but if you don't blind people you will have no problem. It is not a light to run around on high beam all the time. I am not sure how it will work with the plastic lens either. Amazon, $8.97...
click click
Here was another thread on the subject. click
Old Dec 29, 2019 | 12:11 AM
preciate it
Old Dec 29, 2019 | 12:14 AM
so when you say scattering I take it to mean the light is more broken up and not near as concentrated across its reach? Would you say a brighter led would still be quite a bit better than stock?
Old Dec 29, 2019 | 12:15 AM
Originally Posted by klx678
It runs an H4 60/55 watt stock. You could do a hotter bulb too - H4 Halogen 100/55 watt. Technically the 100 watt is illegal in most places, but if you don't blind people you will have no problem. It is not a light to run around on high beam all the time. I am not sure how it will work with the plastic lens either. Amazon, $8.97... click
thank you
Old Dec 29, 2019 | 11:36 AM
Tacoma660's Avatar
If your looking for a pattern that projects out further, i would just get an led bar that has a spot pattern. That way it would be narrow but yet shoot out further down the road
Old Dec 30, 2019 | 02:25 PM
Topher749's Avatar
I have a Cyclops LED in mine and get comments all the time how bright it is during the day. I haven't ridden with it at night so not sure about the pattern.
C
Old Jun 24, 2021 | 11:35 PM
yel911's Avatar
I’m looking for a slip on FMF silencer.
finished my headlight install. I’m fitting everything before I wire it.
Old Jun 25, 2021 | 10:54 PM
Tacoma660's Avatar
i was just throwing around the idea of replacing mine with that one but with the baja design led cube in it! I like the looks of it
