Headers?
#33
I built it myself. At that time, only Muzzy and Big Gun were making full exhaust systems for the KLX. I'd had Supertrapp systems in the past that I liked, so I got an IDS2 slip-on kit for the KLX300 and made the headpipe. I bought a KLX300 headpipe originally, but then used the flange and end ring to make mine own.
https://www.kawasakiforums.com/forum...ent-note-11692
https://www.kawasakiforums.com/forum...part-2-a-11924
#34
Pictures labeled.
"Stock is on the left, 300 is on the right..."
Nice job on the header. I did not want anyone to be confused and think the header on the right was a stock 300 piece.
#35
My bike has a Supertrapp slip-on exhaust for a KLX300. I started out using a stock KLX300 headpipe, but then decided to build my own. Since my bike is apart right now, I dug out the stock headpipe and compared it to the one I'm running now.
As for the diameter, here's the stock headpipe at the joint...
Here's the 300 headpipe at the joint...
#36
Since I had to close up the barn... thought I'd look for them.
I think I misunderstood your post, but here's the 250 and 300 pipes. The 300 (on bottom in first pic) is in fact slight longer.
#37
Well, it seems we're both probably right Zomby. According to the fiche on ronayers.com, there were 2 different headpipes for the KLX300. From 1996-2004, the KLX300 headpipe was part no. 18049-1689. From 2005-2007, the part no. for the headpipe is 18088-0034. Plus, from 2005-2007, they used 2 different mufflers - one for US bikes and one for Canadian bikes.
The clamps for the joint between the headpipe and the muffler are different part numbers too between the 2 headpipes, leading me to think that there is a size difference in the diameters.
I think the headpipe I had came off a 2001. Maybe yours is one of the newer ones?
I always wondered why slip-ons for the KLX300 were listed from '96-'04, even though they were produced until 2007. Now I know.
#39
If they do void your warranty, then bolt the original parts on before taking it back to your dealership!! I got about a days work to get mine back to factory standard condition should any warranty work be needed :-(
But on the other hand parts are cheap in Thailand & dealership labour charge at about $17/hour.....so I'm not loosing any sleep about voiding it......so far!
#40
The dealer I bought my bike from is adding my jet kit. I also ordered my powerbomb header and pro taper handlebars from them. They informed me my warranty is indeed safe.
