Good shock?
Old Nov 6, 2022 | 01:40 AM
MXM's Avatar
MXM
Default Good shock?
I don't know the brand of this shock. Keng in Thailand is selling them. He said it's for approx 120kg rider
Thinking of getting it and some front springs +
330 bore kit if anyone has anything to add.
Old Nov 6, 2022 | 10:30 AM
Don't know where you are located, but the fact is you can have the OEM shock revalved to make it well suited for you and your use. I think it costs a couple hundred dollars at places like Race Tech. That was one of the plusses on a KLX versus some other lower priced dual sports, fully adjustable and revalveable rear shock.
If you live somewhere else you'll have to see if there are places for shock service.
Old Nov 6, 2022 | 08:30 PM
Nigel's Avatar
#2 for Racetech recommendation. Stock hardware is a great piece when re-valved. Plus, it can always be tweaked.
Old Nov 7, 2022 | 02:33 PM
MXM's Avatar
MXM
Guys I've already talked to Race tech. They didn't want to give be the time if e day because I live in Vietnam.
Old Nov 7, 2022 | 04:27 PM
Nigel's Avatar
That is a shame.
It may be worth a try then.
Old Nov 7, 2022 | 10:02 PM
I didn't know where you were located. That's why it's not a bad thing to at least put your country of residence so people can make recommendations. Knowing where you are I'd say do some checking to see if there is anyone there who can do such work. It very likely will not be easy though. If you knew someone in the U.S, well enough you could have them get the work then ship to you, but I'm betting it would be less costly to buy that other shock. So I'd say go for it.
Old Nov 7, 2022 | 10:22 PM
durielk's Avatar
From most comments, the shock isn't that bad on the KLX, the problem is the front forks, it needs valve work. I'd try and order the gold valves from Racetech and see if they will ship them to you. Then have someone local do the work. Then get springs for your wt, which is ?
Old Nov 18, 2022 | 06:46 AM
MXM's Avatar
MXM
120kg +10kg riding gear.
I have someone who can do the mechanical work.
Communicating with the guys in Thailand isn't easy.
Old Dec 29, 2022 | 11:04 PM
freakdaddy's Avatar
MXM, I have a Kustom Kraft 330 cc big bore kit for sale $500 USD + shipping to Vietnam. I tried to install it on my 2018 fuel injected bike but I could not get it to run properly. It has 400 miles on it and is complete with cylinder and piston, you would need to buy base and head gaskets. If you have a carburetor on your bike this is a great deal- half price.
freekdaddy
Old Dec 29, 2022 | 11:48 PM
MXM's Avatar
MXM
freekdaddy
Thanks mate. I also have a 2018. Already have my kit and mechanic is fitting it at present 👍
