Going Deeper into the Exhaust?
Old 10-24-2007, 01:23 AM
sam83's Avatar
Default Going Deeper into the Exhaust?
Drilled the 1/2 hole into the 1st baffle of the stock exhaust and liked the results. Nicer sound and not loud at all really.
NowI've got a long bit in my hands.
Do I go for the 2nd baffle?
I'm also going to replace that pea shooter with something more substantial.
How much louder is it going to be?
Old 10-24-2007, 01:35 AM
mudjunkie's Avatar
Default RE: Going Deeper into the Exhaust?
That pea-shooter is a pipe welded inside the muffler...if you can get it out, you will like the sond..I had to trace a circle around the hole, drill a series of smaller holes to cut it out only to find out it was a pipe welded further in the muffler. BUT with some persistant persuasion with the vice grips, I managed to break it free and continue my baffle reaming..here are the results...
Old 10-24-2007, 02:12 AM
sam83's Avatar
ORIGINAL: mudjunkie
What is it welded to? Just the 1st baffle or the 2nd one also?
Old 10-25-2007, 12:31 AM
mudjunkie's Avatar
just the first one..the pipe is only about 4-inches long (if that) it's attached at the end of the muffler and to the first plate (baffle) inside the muffler.
Old 10-25-2007, 02:01 AM
sam83's Avatar
So, did you go after the 2nd baffle too?
Old 10-25-2007, 03:00 AM
KLXer's Avatar
I can't see all this drilling keeping your spark arrestors intact.
Old 10-25-2007, 06:56 AM
stellar_d's Avatar
+1. get a slipon, you'll be happy you did. or even a fullsystem. you wont be sorry. If you do want quiet though, stay away from BG and Muzzy
Old 10-25-2007, 02:24 PM
DJFields's Avatar
I agree, I did all of the above with the drilling + more ( I used a hole saw - see my post on it.) and I still like the slip-on better plus I stillmaintain the spark arrestor. Plus it looks way better!
Old 10-25-2007, 09:33 PM
sam83's Avatar
Okay, just where is this spark arrestor? I thought it was pretty far down beyond these two baffles.
Also, reccomendations for a relatively quiet slip on?
I won't be getting one anytime too soon as my fun money is getting tight. Just received my Utah skid plate, Scott's shark fin and Acerbis Rally Pros! Whoohoo!
Old 10-25-2007, 10:21 PM
KLXer's Avatar
Nope, it is right on the end. The check method for a spark arrestor is to stick somehthing in the pipe. It has to hit it within "x" inches.
Quiet pipes standard (as apposed to adding quiet core inserts):
FMF Q series
Pro Circuit 496
Quick Reply: Going Deeper into the Exhaust?
