Gas leak noticed from float bowl vent
Old Apr 21, 2013 | 10:07 PM
Stashu's Avatar
Default Gas leak noticed from float bowl vent
I just started my 2012 KLX250s from it's winter sleep. I went up and down the driveway a few times and shut the bike off. I noticed the carb float bowl leaking gas excessively...Ideas? warranty?
Thanks!
See link:
2012 KLX250s gas leak - YouTube
Old Apr 21, 2013 | 11:36 PM
MaximusPrime's Avatar
Did you empty the carb before winter and not retighten the drains allen bolt?
I'd back it out a little and then tighten it back up.
Hope that helps, it's all I got.
Old Apr 22, 2013 | 12:58 AM
ITHAPPENS's Avatar
Float could be stuck down. Give it a few taps, may break it loose and re-seat the needle. Good luck! Mine fired right up today for the first time this year. Still a bit chilly but got out for a couple of hours anyway!
Old Apr 22, 2013 | 06:23 AM
hounderd's Avatar
As stated above, the allen bolt on the drain should be tight. If that's doesnt fix it, your float/needle might be stuck, or your float level might be off.
Old Apr 22, 2013 | 02:08 PM
jeffzx9's Avatar
Careful with that axe, Eugene. Make sure you don't put the Magilla Gorilla on that allen wrench. Just "medium-snug."
Attached Thumbnails Gas leak noticed from float bowl vent-magilla-gorilla.jpg
Old Apr 22, 2013 | 03:04 PM
hahahah.... ive been accused of that a few times. Im getting better though.
Sounds like float needle is stuck.
Old Apr 22, 2013 | 04:14 PM
Yeah, residual fuel can break down during winter and make a gummy residue in the needle and seat and/or float pin pivot causing a fuel overflow.
Old Apr 22, 2013 | 04:51 PM
Bringing out the 30 year old reference, nice!!!
Old Apr 22, 2013 | 05:38 PM
jeffzx9's Avatar
Just seeing who is paying attention....
Old Apr 22, 2013 | 06:16 PM
Im 30 years old does that count?
