Gas leak noticed from float bowl vent
I just started my 2012 KLX250s from it's winter sleep. I went up and down the driveway a few times and shut the bike off. I noticed the carb float bowl leaking gas excessively...Ideas? warranty?
Thanks! See link: 2012 KLX250s gas leak - YouTube |
Did you empty the carb before winter and not retighten the drains allen bolt?
I'd back it out a little and then tighten it back up. Hope that helps, it's all I got. |
Float could be stuck down. Give it a few taps, may break it loose and re-seat the needle. Good luck! Mine fired right up today for the first time this year. Still a bit chilly but got out for a couple of hours anyway!
As stated above, the allen bolt on the drain should be tight. If that's doesnt fix it, your float/needle might be stuck, or your float level might be off.
1 Attachment(s)
Careful with that axe, Eugene. Make sure you don't put the Magilla Gorilla on that allen wrench. Just "medium-snug."
Originally Posted by jeffzx9
(Post 494270)
Sounds like float needle is stuck. |
Originally Posted by EMS_0525
(Post 494274)
hahahah.... ive been accused of that a few times. Im getting better though. :D
(Post 494270)
Originally Posted by deej
(Post 494281)
Bringing out the 30 year old reference, nice!!!
Im 30 years old does that count?
