Fuel reserve for 2009 klx250S
Old Jun 22, 2009 | 06:26 PM
karlcchen's Avatar
Default Fuel reserve for 2009 klx250S
I have run into this problem several times:
I was able to start the bike, but as soon as clutch is released, engine stalled. Thus I found I need to switch fuel to reserve. But I only used just a little bit more than 1 gallon. As I remembered that fuel tank capacity is 2 gallon.
Karl
2009 KLX250S
Old Jun 22, 2009 | 07:13 PM
BigGreenBastard's Avatar
Is there a question in there? I'm no expert but the clutch has nothing to do with the reserve fuel.
Old Jun 22, 2009 | 09:29 PM
karlcchen's Avatar
Sorry about the confusion. Clutch got nothing to do with it. I should just skip the clutch. Basically when engine started it was running with fuel in the hose and when clutch was released and throttle opened wide, fuel requirement starved and engine stalled. After a few attempt, engine will not start as there is no fuel in the hose.
Just want to know others experience about how much fuel is used before need to switch to reserve?
Karl
2009 KLX250S
Old Jun 22, 2009 | 10:15 PM
KDXmike's Avatar
You should have to switch to reserve somewhere between 90 and 100 miles if my memory serves me...
Mike
Old Jun 22, 2009 | 10:26 PM
Oh ok, for a second there I thought you had the kickstand down, I've done that a few times....
Old Jun 23, 2009 | 07:49 AM
MaverickAus's Avatar
The tank is 1.9 gallons, I think from memory reserve is around 0.4 gallons, therefore it goes that main is approx 1.5 gallons
Old Jun 23, 2009 | 12:02 PM
Sid Post's Avatar
Yes, put your kickstand up or get the switch fixed.
Old Jun 23, 2009 | 06:46 PM
gr8stdane's Avatar
I have an '06, but my bike just shut off at 87 miles. switched to reserve for about a mile, and then I put in 1.43 gallons to fill it back up, so should be roughly .5 in the reserve. Personally I don't feel like finding out EXACTLY. It's about 99 degrees in the midwest today.
Old Jun 23, 2009 | 07:52 PM
gr8stdane's Avatar
Oh, and I should mention there was some trail riding in there as well, if it were all street riding I probably would have made it over 90 miles before switching to reserve.
Old Jun 24, 2009 | 09:08 AM
Sid Post's Avatar
With a Clarke 2.7Gallon tank I get 149 miles to reserve and 169 to empty when street riding FWIW.
