Front end singing/whistle
Old Jun 5, 2013 | 12:20 AM
NEWPARTSRULE's Avatar
Talking
TNC, We're talking about the front end, not the back end.
Old Jun 5, 2013 | 07:02 AM
donaldor's Avatar
Originally Posted by TNC
OK...how do you explain the noise of those who don't have the speedo drive gear or cable drive anymore due to replacing it with an electronic instrument panel? Either we have two noises going on here, or we still haven't identified the source.
The maintenance I referred to is for the electronic speed sensor on a 2012.
Old Jun 5, 2013 | 02:43 PM
Yep, understand that, but the Vapor doesn't use anything but a wire and magnet...nothing to make any noise. You gut the OEM speedo drive...worm gear and all...and just use it like a conventional wheel/hub spacer. And yes...I've even looked at the seal on the old speedo drive as a possible source, but it's not the source either. I still think that we're not all experiencing the same sound and same source...perhaps...though the sound as described sounds quite similar.
Old Jun 8, 2013 | 03:53 PM
mee2yoo's Avatar
I just did a desert ride over Memorial Day Wknd. Mine started making the same noise. It was even noticeable on the GoPro video. I came home and changed the front wheel bearings out and the sound is gone. May be your culprit too.
Old Jun 8, 2013 | 04:53 PM
I have new wheel bearings in both ends...seemed like a waste of time as the OEM units looked fine and still had grease. Noise was there before and noise is still there. But again, it's very infrequent and not repeatable upon demand.
Edit: See, this is what I was talking about. One guy tries one thing and the noise disappears, and another tries something else and the noise disappears. Other than the noises actually being something different on different bikes, I'm thinking that just the removal or tinkering with the front end or wheel/axle is disrupting whatever was causing the noise. Fortunately, it appears obvious that whatever it is isn't a real problem, because none of us are flying over the bars or having the engine blow up as a result...LOL!
Old Jun 21, 2013 | 03:43 PM
MaximusPrime's Avatar
OK, so I have the noise too, never thought much about it until this thread showed up.
Tried braking hard and soft when hearing it - no change.
Took the wheel off and reset it - no change.
Checked wheel bearings - they are good .
2 days ago I noticed when I down shifted from 2nd to 1st it appeared. Upshifted to 2nd and it went away, immediately.
It's something to do with being in 1st gear. Definitely happens with the clutch in, not sure about it with the clutch engaged.
Discuss...
Old Jun 21, 2013 | 11:19 PM
Lotrat's Avatar
Man, your bike must be messed up... or completly fine. I'm sure of it.
Old Jun 22, 2013 | 12:58 AM
  #28
Discuss...
LOL!...this is just what I meant in my comment above. There's almost no rhyme or reason in most cases. Notice that those who got the occasional noise to go away don't all have the same solutions. And in your case, MP, you only get the noise in first if I read correctly...I can get it in any gear...when it does show up. It's almost become amusing trying to positively identify this noise. Like I said, though, it's good that it's obviously not something serious.
Old Jul 22, 2013 | 04:44 AM
  #29
Lotrat's Avatar
So I captured the whistle on video. After I shot the video, I just hosed off the bike and the sound was gone...
http://i523.photobucket.com/albums/w...psb1a3c021.mp4
Old Jul 22, 2013 | 05:21 AM
  #30
That's interesting, Lot. I can't be sure that's what I hear on mine when it's actually rolling, but I can't swear it wouldn't be the sound. On the other hand, I wouldn't think that sound you have there would be very intense while the bike is running and with a helmet on. I don't know.
