Front brake caliper slide pin inside hex rounded out
Old Aug 22, 2017 | 10:12 PM
snappster's Avatar
Default Front brake caliper slide pin inside hex rounded out
Front brake caliper slide pin inside hex rounded out. Brand new hex tip will not engage, neither will a torx bit. I put the caliper in a vice to better work on it. Plan to soak in penetrating fluid. Anyone have this same problem and get the little bastard out? Will order new pins tonight. Damn, my bike is down now. Had to pull the brake pads out cause my dumb *** got some oil on the rotor and pads. I am thinking about drilling out the thing but will still have to address the remaining threads after getting the pads out.
Old Aug 22, 2017 | 10:42 PM
snappster's Avatar
After my last I remembered that buried in my toolbox is a set of easy outs, snap on brand, that I have seldom had need for. A few minutes after soaking in nut buster I hammered my 7/32" easy out in and gently turned my long *** 7/16" double box end wrench and she came loose. Dave breathes a sigh of relief because he didn't jack up the caliper in the process. Bitch was tight. Tried a chisel and just peeled off metal. I guess compared to the cost of a new caliper the easy outs paid for themselves.
Attached Thumbnails Front brake caliper slide pin inside hex rounded out-image-39-.jpeg
Old Aug 23, 2017 | 12:08 AM
klxnoobie's Avatar
I used one of these to loosen those pins https://www.mscdirect.com/browse/tnp...CABEgIwr_D_BwE
Old Aug 23, 2017 | 02:46 PM
Those simple little hammer smacked impact tools are amazingly effective. I have a lot cheaper version I've had for decades, and they flat out work. The beauty is they almost never bugger up the head of the fastener if you use the tool halfway correctly.
snappster, a little antiseize will go a long way for the next time.
Old Aug 23, 2017 | 10:10 PM
Howlinsage's Avatar
If you have a welder ,I can give you a surefire method.
Old Aug 23, 2017 | 10:58 PM
snappster's Avatar
I have a couple of those buried in the tool box somewhere. Hope I remember them next time a need arises.
Old Aug 24, 2017 | 10:19 AM
klxnoobie's Avatar
Works well when used with one of these
Amazon Amazon
Old Aug 24, 2017 | 06:58 PM
MaximusPrime's Avatar
Glad you got it sorted so easily.
I had a pin go south on me too.
It happened when I made the mistake of using an allen wrench instead of an impact socket (which I own now) on my stuck pin.
I just drilled the whole head out with my drill press and vice. I used a drill bit slightly larger than the pin. That let me free the head from the actual pin. Once the head was disconnected from the pin it freely spun out. Then I drove the pin out with a punch.
And fortunately I had a spare pin on hand.
I now use an impact socket to do the job.
I also pull the pin a couple times a year and clean it up and make sure there's lube on the threads.
Ralphh85
KX250 & KX250F
Jun 17, 2014 09:28 AM
OldGuy
Aug 30, 2010 03:25 PM
horizonod
Dec 14, 2008 01:21 AM
tron_2000
ZZR 600
Jun 23, 2007 10:14 AM
