freeway wiggle?
Old Jul 18, 2011 | 06:40 PM
RaceGass's Avatar
Add rim locks on the pavement and you have one squirrely paint shaker....
Old Jul 18, 2011 | 07:21 PM
T_i_G_e_R's Avatar
A funny thing about freeway wiggle I noticed.. it is worse with the 606's less with the 605's.. if you simply LET GO of the handlebars while it is happening, it stops.. try it.. while going 70'ish gps, loosen your grip completely.. the wobble goes away.. why is this?
Old Jul 18, 2011 | 09:30 PM
Highbeam's Avatar
Not if you finish the job by installing wheel weights oppopsite the rim-loks.
Old Jul 18, 2011 | 10:32 PM
Or by installing two rim locks on opposite sides.
Old Jul 18, 2011 | 11:54 PM
Mr.P's Avatar
The op and i both have klx250SF not S
I would like to get more power so i can gear up and get down in the 7500 range at 80mph...if it will hold it. I will try a pumper carb first.
Old Jul 18, 2011 | 11:56 PM
RaceGass's Avatar
Also certain brands of tires mark where the light spot of the tire is. Letting you know where to line up the tire with the rim lock. Pirellis for instance.
Old Jul 19, 2011 | 05:12 AM
HeavyFuel's Avatar
Yup, listen to Highbeam. Time for you to balance those wheels.
Old Jul 21, 2011 | 01:26 AM
T_i_G_e_R's Avatar
certain tires wobble more.. soft knobbies are the worst.. street tires or 80/20 ds tires dont wobble
Old Jul 21, 2011 | 02:10 AM
HeavyFuel's Avatar
I'm running full knobbies (Kenda Trakmaster) and I get no wiggles or wobbles at any speed. I've would have been agreeing with you up until the day I fixed the steering head bearings. That's what cured the wobbles for me.
Old Jul 21, 2011 | 03:17 PM
David R's Avatar
I slow down when its windy on a little bike. Its not as bad on my 600 lb road bike.
Glad it works for you.
David
