fork spring replacement
Old Jan 14, 2008 | 11:25 PM
mudjunkie's Avatar
Default fork spring replacement
[:-]Hi guys, I have a question about the fork springs...I am ordering new springs tomorrow and wonder ifI have to buy new fork oil as well or will the oil currently in the forks be okay? The specs listed with the springs calls for 5 weight and I do not know what is the OEM weight in the front forks...any help would be great..I plan on using nobrakes report to help put them in. thanks. FYI new springs will be .41kg/mm andI weigh 175lbs (hopefully down to 170lbs by Spring)
Old Jan 15, 2008 | 12:11 AM
Default RE: fork spring replacement
Fork oil is cheap right? Just change it..... well that's my opinion.
Old Jan 15, 2008 | 12:15 AM
AgoosSS's Avatar
Cracking open the forks. I would change the oil without even thinking otherwise. Changing the fork and shock oil is a maintenance item.
Old Jan 16, 2008 | 12:25 AM
RIKLX250S's Avatar
Fork spring question also. I know what size spring I need .46kg but not sure of the rest. I notice numbers like this in front of the 43.2x449mm is this the the diameter and which would be correct for our bikes?
Old Jan 20, 2008 | 03:33 PM
daveg's Avatar
I just changed my springs(.44) using the factory oil seems ok.
miniman
Apr 9, 2015 05:14 PM
Pastor Dude
Aug 10, 2009 01:13 PM
mandark
Nov 20, 2008 01:20 PM
vurtle
Mar 31, 2007 08:37 PM
keevo
Apr 6, 2006 07:24 AM
