Fork sag
Old Sep 15, 2011 | 08:03 PM
Originally Posted by linkin5
The only times I've ever tweeked my bikes forks was in a get off, never ever from changing tires.
Me either, but if I understand correctly, isn't that what happened with the OP? I've heard of loosening the triple clamp to get a tweak out.
Old Sep 16, 2011 | 12:30 AM
While the KLX manual makes no mention of it, many forks with axle clamp setups similar to the KYB USD fork require you to loosely fit the axle clamp plate and then stroke the fork vigorously before doing the final torquing of the clamp nuts/bolts. This tends to center the wheel/hub in the fork legs so there's no axle or fork leg bind. I think this may be what Scott is referring to. While I'm not positive that this is required on our KYB fork, I do it on mine when reinstalling the wheel just for grins.
Old Sep 16, 2011 | 03:01 AM
Huh huh , he said stroke it vigorously. lol Just kidding , that sounds like a great tip to file away for the next tire change.
Dan
Old Sep 16, 2011 | 03:14 AM
Guido's Avatar
Actually I didn't mention it, and hadn't really made the connection till I read your post, but I did tweak the forks in a crash last year. Everything worked fine but the handlebars were cocked to the right just a bit. About a month ago I got tire of the skewed bars and loosened the triple clamp bolts, locked the front wheel between my legs, and gave a mighty heave on the bars. I heard a small crack and everything then lined up. But I didn't loosen the axle clamp after that and I bet that's what bound up the fork. Nevertheless I think TNC's advice is good - to pump the forks a few times before you tighten down the clamp if you've had the wheel off.
Old Sep 16, 2011 | 04:47 AM
Originally Posted by TNC
stroke the fork vigorously ... I do it on mine when reinstalling the wheel just for grins.
Ya, I bet that brings the grins. (just had to...esp after dan's post)
Guido - thanks for the clarification. What I take from this is if they tweak, loosen the triple clamps and axle, and then of course, stoke vigorously.
je2000
Aug 31, 2008 04:39 AM
pie4foou
Apr 2, 2008 08:41 PM
telejojo
Ninja ZX-14
Sep 14, 2007 05:42 AM
Ziguy
Feb 2, 2007 12:19 PM
xmxracer
Jan 5, 2006 08:02 AM
