Fork end cap
Old May 2, 2019 | 01:56 PM
583KLX's Avatar
Default Fork end cap
I'm changing my springs and oil out on my 2012. I've been searching for the size of the end cap so I know what size of socket or wrench to get. I think it's 30mm in size but only found one reference. I wanted to double check.
Thanks
Old May 2, 2019 | 10:31 PM
Tacoma660's Avatar
i just use a adjustable wrench works fine for me
Old May 3, 2019 | 08:45 PM
ctbale's Avatar
Can you get a tape measure across it. Then convert the inches to millimeters. 30s my guess too
I got seals coming from my 2012 also. Did you get the seal driver tool? On old style forks I just used to use the old seal as a driver after taking off the rubber on the OD. Can't really do it with this style unless I cut it in half.
Keep the updates coming will help me out
Old Jul 5, 2019 | 03:17 PM
583KLX's Avatar
Default Update
Done. Went easy. No fork changing tool. Just a wrench and basic drivers to do it all. Watch the video on the guy that uses a piece of string to pull his spring up
Old Jul 9, 2019 | 08:30 PM
GBAUTO's Avatar
Just make sure you're using a metric adjustable wrench...
Old Jul 9, 2019 | 10:55 PM
You mean like these:
Old Jul 10, 2019 | 03:02 AM
Brewster's Avatar
And don't forget to loosen the pinch bolts in the upper triple clamp.
Ride on
Brewster
Doga
Oct 14, 2011 08:03 PM
gwalleye
May 5, 2009 06:26 PM
oldman
Ninja ZX-7R
Sep 21, 2008 02:38 AM
Kevin
Jul 11, 2007 06:35 PM
vurtle
Mar 31, 2007 08:37 PM
