FCR35 problems. Need help please.
Old Dec 16, 2021 | 08:55 AM
savethebest's Avatar
Default FCR35 problems. Need help please.
Hi everyone. I'm currently in the process of building a klx330 with fcr35 carburetor (old model) while the bike is running great with good torque, the carburetor seem to have a problem of leaking gas (I suspect the case of overflow but cant find the exact reason why). I'm used the rebuild kit to replace the orings and the gasket but the problem still remains. The gas is leaking through the slow jets and the needle (area showed in the picture)
But the funny thing is, when testing without the bowl, the carb is working fine and dont even leak a drop!!
When instal the bowl and adjust the float bowl level to the lowest possible, it still leaking.
If anyone ever occured the same problem. Please let me know, this drives me crazy.
Thank you guys so much!
Old Dec 16, 2021 | 04:11 PM
Another note: I also replace the float valve and the float valve seat as well.
Old Dec 17, 2021 | 12:57 AM
durielk's Avatar
You need to figure out why the float valve opens when you put the bowl on.
Old Dec 17, 2021 | 01:35 AM
I still dont know why, the float valve dont have any problem sliding in and out of the valve seat. Will go over the bowl today to find the problem.
Old Dec 28, 2021 | 05:16 AM
After so many tear down of the carb. I found the reason why. The slanted fcr has two air passage along the "KEIHIN" logo on the side. If these two passage clogged up the carb will draw fuel from the bowl no matter what the possition of the float valves ( suction I supposed). Lesson learned: "remember to check all the passage when cleaning a carburetor".
Arpy Barner
Jun 28, 2018 10:12 PM
Stashu
Apr 23, 2013 04:58 PM
ladyvorlon
Jun 1, 2010 07:30 PM
batts65
Nov 11, 2008 03:40 PM
chris page
Nov 5, 2006 03:30 AM
