exhausts
Old Oct 1, 2007 | 11:54 PM
jaylaudeman's Avatar
Default exhausts
This is my first bike and I want to get more power out of it and I'd like to change the exhaust but am not really wanting to spend like $450 for a full system. What differances would there be between a slip-on system and a full system. I was looking at the Muzzy's, if Ijust got the slip-on wouldI be able to later get the rest to add on if needed later.
Old Oct 1, 2007 | 11:56 PM
Default RE: exhausts
uh o...... if i were to do it again id just get a slip on, personally id get the two bros slip on.
Old Oct 2, 2007 | 12:16 AM
stellar_d's Avatar
The theory is that if you keep stock header,you'll get more low end torque because its smaller. But with a bigger one you should get more high end?
I've compared both Muzzy and Big gun full systems and didn't notice much of a difference outside of the sound, and the way they fit. Both good pipes.
Availability was an issue for me too, so I ended up with the Muzzy. If I had to do it again, I'd say the same as Eric and try a slipon.
Good luck!
Old Oct 2, 2007 | 12:28 AM
KLXer's Avatar
If you dont want to spend the money a 300R muffler & headpipe with an opened airbox & Kehin rejet is very effective. I'd estimate at least 90% of what you could obtain with any aftermarket system or jet kit.Cost you under $100 for sure.
Thats said, I'll take my Pro Citcuit pipe & Dynojet rejet over the 300R pipe & Kehein rejet I used to have but this setup is about $350.
You will find headers discussed ad naseum.
Bottom line is to get that 250S muffler off there ASAPand replace withany decent 300R or aftermarker option & rejet at the same time.
The waiting begins...
Old Oct 2, 2007 | 02:02 AM
HawaiiRider's Avatar
+1 on the Two Brothers. Looks great, sounds great, works great. It's just $$.
Old Oct 2, 2007 | 02:26 AM
bryantjt's Avatar
Sound clip of the $100 special.......
http://s88.photobucket.com/albums/k1...KLX9-22-07.flv
Old Oct 2, 2007 | 04:28 AM
kawikathy's Avatar
HMF is the only way to fly guy!
Old Oct 2, 2007 | 04:33 AM
klx250s_rider's Avatar
10+ on the HMF Kathy!
Old Oct 2, 2007 | 04:36 AM
kawikathy's Avatar
How's your leg doing after that spill you took Saturday, I couldn't believe how that idiot cut you off. It was one of the better crashes I've seen in a while!
Old Oct 2, 2007 | 04:37 AM
It only hurts when I walk on it!
