exhaust butterfly
Old Nov 13, 2012 | 02:18 AM
darkmarc's Avatar
Default exhaust butterfly
I remember back in the 60s my neighbor had a honda scrambler. He took the huge muffler off and ran straight pipes with butterfly baffles in the tips. I ride in some places I'm not supposed to so I wanted to keep the bike quiet, but still be able to open it up. I made this out of a 5/8" flat washer a couple 6mm bolts with flats ground on them,and mini allen bolts I got from an r/c hobby store. The hobby store also had the 4mmx14mm allen bolts for the carb bowl. The butterfly does help a little,although it's still not too loud with just the pea shooter drilled out.This might help guys with aftermarket systems that are too loud.
marc
Old Nov 13, 2012 | 02:51 AM
From the old days those were called "snuff-or-nots"
Old Nov 13, 2012 | 02:55 AM
drm's Avatar
drm
nifty idea there. tell us about your graphics on the front and rear plastic.
Old Nov 13, 2012 | 03:41 AM
darkmarc's Avatar
Graphics were an attempt on my part. I cut sign vinyl into 1/2" strips and mitred the ends, I'm happy with the side panels ,still unsure on the headlight. I did'nt want to go camo there as my biggest fear on the street is someone not seeing me & pulling out, so I wanted something brighter.
marc
Old Nov 13, 2012 | 02:36 PM
Ride Now's Avatar
I am old enough to remember those "Snuff or Not" baffles........... Good idea! Looks like the stock muffler on there; did you just "hole saw" out the peashooter and bolt/rivet on the aftermarket exhaust end? If so, do ya have any pics of the procedure. I gotta couple of ideas about an exhaust tip but would like to see how others have removed the stock tip. Thanks, Dennis
Old Nov 13, 2012 | 11:00 PM
wildcard's Avatar
Heres how i did mine, used a torch instead cause i didn't have a hole saw.
https://www.kawasakiforums.com/forum...inished-35018/
Old Nov 14, 2012 | 12:11 AM
darkmarc's Avatar
Sorry, I did'nt take pics of assembly,but it's super easy. i got a $30 billet tip off ebay, used a side grinder on some 6mm bolts,fabbed a little tab lever,drilled some holes. I used a 1" hole saw on the peashooter,but even after grinding off all the tip,the saw wasn't long enough to completely cut the inner weld. I had to fatigue the last bit by wiggling the tip back & forth to get it out.The small holes were a little tough.I broke a drill bit &drilled off the edge one time,so use patience and think small.
marc
Old Nov 14, 2012 | 12:50 AM
Ride Now's Avatar
Thanks Wildcard. I've had that link to your exhaust mod bookmarked for quite awhile now; nice job. Just looking for all the pics I can find about different ways to remove the stock "peashoooter" tip. I'll post some pics when I dig into mine.
neonarc
Jun 28, 2015 02:58 PM
CKawi
Jul 7, 2008 02:21 PM
kawiben
Jul 29, 2006 10:42 AM
green636
Jul 1, 2006 07:16 PM
metroallstar2003
Oct 1, 2005 06:06 PM
