Engine Parts from klx250s 09 will be fit to Crankcase from klx250r 96?
hello
i have engine from klx250s 2009 , i wont to install this engine prats into crankcase from klx250r 1996
can i do it?
thank you
can i do it?
thank you
i will use the crankcase from 96 only.
the parts are the same , the only diffrent is the CRANKSHAFT.
do you think its will work?
and the both cases are look the same.
the BEARING-BALL are the same.
this is 96
1996 Kawasaki KLX250R (KLX250-D4) Crankcase | Babbitts Kawasaki Parts House
and this is 2009
2009 Kawasaki KLX250S (KLX250T9F) Crankcase | Babbitts Kawasaki Parts House
they look the same , but serials number are diffrent.
I thought the main problem with older KLX cases was the issue of trying fit a later cylinder on those cases. I don't know this personally, but I recall something about the case opening for the older model not being large enough to accomodate the newer cylinder skirts where they extend into the case opening...at least not without some machining work. Anyone confirm that?
you can see here
11005-0112 - CYLINDER-ENGINE - Kawasaki OEM Parts - Cheap Cycle Parts
and if you look in the end of the page you will see that this part (cylinder-engine) fits these vehicles (klx250s) 2010.
you can see here
yes, the 96 case is like new .
this is 96
and this is 2009
this is 96
and this is 2009
