Engine Oil..
Old Aug 15, 2008 | 12:37 AM
Sid Post's Avatar
I use Castrol Octaveo 10W-40 and try to change every 1,000 miles (1,600 Km's). Be sure to save an oil ring or two from the Fram Filters in case you break one using a different filter without the replacement. I've gotten about 10 oil changes on the factory oil ring so far.
If you shifting gets a little tough, notchy, noisy, etc. you should probably change your oil. Fresh oil helps the transmission shift easier and smoother and quiets it down some too.
Old Aug 15, 2008 | 10:53 AM
Savagekilla's Avatar
This is definitely motorcycle oil .. Oil ring or O-Ring?
boarders09
May 13, 2020 03:06 AM
Israel-klx250s
Mar 4, 2012 08:33 AM
09klx
May 12, 2010 08:43 AM
kawi636
Apr 4, 2006 09:26 PM
dbblo
Dec 17, 2005 07:32 PM
