Engine noise I'm noticing under acceleration
Old Apr 15, 2016 | 11:50 PM
s10gto's Avatar
Originally Posted by 2veedubs
Sounds good to me. The stock exhaust is so quiet, you can hear the subtle motor noises. Get an aftermarket slip on muffler, problem solved.
I agree. With stock exhaust the engine is very mechanical sounding. I believe you are fine. All I hear is normal valve train and intake noise.
Old May 17, 2016 | 04:14 PM
RsoJim's Avatar
Default engine noise
I am reading lots of good suggestions to try. I had the same problem on my 2012 KLX250S with 5000 miles showing. Under acceleration I had a noise that sounded exactly like plastic vibrating on metal. I removed everything I could and it was still there. Turned out it was the front sprocket with some wear. I am changing both sprockets and chain this week. I ordered the sun sprockets and chain from e-bay. I have used these before am satisfied with their use. Every time I rode my bike the noise got progressively worse until I was afraid something was ready to fall off. Now to change the subject just a little bit, I added the ground wire and now my high speed miss is gone and it feels like I have more mid range power.
Old May 19, 2016 | 11:45 AM
MaverickAus's Avatar
Sounds normal to me
Old May 20, 2016 | 01:21 AM
Listen closely around the engine to try to locate the source of the noise.
Old Mar 15, 2020 | 12:32 AM
Jeromie Norton's Avatar
Default I have that exact sound !!!
Originally Posted by queen of spades
New owner of a 07 KLX250S with 4k miles. During a ride around the hood earlier tonight I noticed a noise that sounded a bit odd. It's a kind of rattle or light knock when the bike is under hard acceleration. I've experienced ping/detonation on several bikes but this doesn't sound the same. The engine almost sounds like a diesel when the noise occurs.
Bike is mostly stock. It has a K&N air filter, stock carb & exhaust. As far as I know a jet kit wasn't installed.
What could the noise be if not ping?
This isnt just regular engine sound mine started at 4000 or 5000 and I thought it was my cam chain got new cam chain didnt fix then I thought it was my oil pump because my sound only happens after hard accelaration at high rpms but I checked a few things and its not.... I have thought of everything except the crankase releif valve and the sound seems to be coming from the front of the motor right were this valve is so im going to replace it and see if that works because I have a feeling I overfilled it a couple of times and thats what went bad
*correction* I looked up what I meant to say.... its the air suction vavle on the diagrams for the cylinder head ... I think it goes back and makes the "suction" sound I hear maybe this is your problem too?
Old Mar 15, 2020 | 07:32 PM
Jeromie,
Welcome to KF.
You're replying to a several year old thread, just FYI.
Check into Krieger's manual cam chain tension adjuster as a replacement to the Kawasaki auto unit. The stock unit is a well known failure point resulting in noise in the rpm range you're describing. I have one, as probably hundreds of other KLX250 owners.
Justin Davis
Jun 26, 2017 02:51 AM
Duomike
Dec 20, 2015 10:43 PM
codyw2012
Sep 8, 2012 12:59 AM
Austin83
Dec 23, 2011 10:58 PM
Buddy Lee
Mar 9, 2008 05:34 AM
